'Run from here' calls remapped M-code multiple times
- chowderhead
- Thank you received: 11
22 Jul 2023 16:13 #275998
by chowderhead
Replied by chowderhead on topic 'Run from here' calls remapped M-code multiple times
My user name is hardly ironic; I apologize for being thick and I greatly appreciate your insight and help! The application at hand isn't conventional - rule breaking is kind of the point. Consider the coating a tenacious flux; it's not so much a hardware problem as a process reality.
And to complicate things more, the tool path is not simple. A change in direction is likely to occur before arc initiation, which I think means the intervening g-code must be repeated, but with a stable arc. As for tolerance, I would prefer if the path over-ran the arc initiation point.
Everything works to plan if the tool path runs to completion without upset. The problem occurs when recovering from upsets and invoking 'Run from here.'
- Thank you received: 5929
22 Jul 2023 16:57 #276004
Replied by tommylight on topic 'Run from here' calls remapped M-code multiple times
Did you try running M55 from MDI before "run from here"?
- chowderhead
22 Jul 2023 17:47 #276007
by chowderhead
Yep. It's counterproductive as it deletes the temporary g-code file same as what the interpreter does...
- chowderhead
24 Jul 2023 14:15 #276154
by chowderhead
I've come up with a workaround, but it it seems kludgy: Rename the temporary g-code file if it exists at the time the arc extinguishes. At initiation of the arc, check if the renamed file exists and rename back to the original name.
I was hoping there existed a flag of some sort to indicate the g-code wasn't actually being executed, just parsed to reestablish state. It seems something like a halui.mode.parsing (or whatever would be the logical pin name) would be useful.
Thanks for the help!
Time to create page: 0.069 seconds
