Lathe turret tool changer with absolute encoder
10 Oct 2023 23:31 - 10 Oct 2023 23:32 #282715 by Trav328
I'm at the point in my retrofit where the last 2 big things I would like to wrap up are the spindle winding selection and the tool changer,  I'm unsure how to proceed with the tool changer.
It's a pragati 8 tool , driven by a 3 phase motor and absolute encoder with a prox switch for tool clamp verification. This turret simply runs the motor forward or backward and has a internal cam system for unlocking , no prawl , no locking pins , no lifting.
I have the 3 phase motor running off a mollom vfd and I can manually cycle the tool changer forward or reverse , the vfd supports +10v analog signal and can have a reverse input.
The output from the encoder is 3v but i forgor to grab a pic of that page.
I have the encoder and prox switch powered,  the prox switch is wired to a input on my 7i95t and is functioning.
my mesa setup is 7i95t-7i83-7i84
debian 12 , linuxcnc 2.9 gmoccapy
I guess I'm looking for advise on how to proceed , tool changer setup seems unique to every machine . And I can't find much info about absolute encoders , I would be up to ditching the encoder and going with some kind of "tool home" sensor if it's easier.
Last edit: 10 Oct 2023 23:32 by Trav328.
11 Oct 2023 10:56 #282737 by andypugh
This looks like a simple binary position encoder and looks like a perfect fit for the "carousel" HAL component.
In fact you can probably just set up the tool-change position in the INI and in the HAL connect:
loadrt carousel pockets=9 encoding=binary dir=2 num_sense=4 parity=0
addf carousel.0.servo-thread
net tool-pocket iocontrol.0.tool-prep-pocket =>carousel.0.pocket-number
net tool-sel-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-start iocontrol.0.tool-change => carousel.0.enable
net tool-change-done carousel.0.ready  => iocontrol.0.tool-changed
You might want to put the carousel comp in the tool-prepare loop rather than the tool-change loop, maybe experiment to see which works better.
Note that by default LinuxCNC _requires_ an M6 command and a G43, whereas most lathe controllers do not. This can be changed via a remap.
You then need to connect the carousel motor-fwd and motor-rev pins in such a way as to operate the motor, and wire the encoder outputs (including strobe and parity) to the correspoind carousel comp outputs.
linuxcnc.org/docs/2.9/html/man/man9/carousel.9.html
The following user(s) said Thank You: Trav328
11 Oct 2023 15:31 #282755 by Trav328
Thank you for the direction , I was reading about carousel  bit last night , looks like it will fit the bill.
For wiring of the encoder should the signals be connected to the i/o of the 7i95t ? I'm still confused on that part but I did find an example from bigjohnt who uses a similiar encoder and I believe that's how it was wired.
11 Oct 2023 15:52 #282756 by andypugh
I think that you are probably wrong when you say
The output is shown as being PNP which means that it is effectively a switch to the positive rail that feeds the Proximity sensor. This could be anywhere between 10 and 30 V.
www.se.com/uk/en/faqs/FA142566/
When wiring his sort of thing it is helpful to think in terms of current flow, rather than voltages.
When the sensor is tripped it will allow current to flow from the proximity sensor brown wire and out of the black wire towards the blue wire.
If you take the black wire to the Mesa card then the input will be high if current flows from the black wire, into the Mesa connector Input terminal (for example INPUT0), through the LED in the optocoupler on the Mesa board, out of the INCOM0,1 terminal and back to the blue wire.
Thoigh you wouldn't typically run that last wire back to the actual sensor, but rather connect it to some point on the same signal ground net.
11 Oct 2023 17:42 #282764 by Trav328
You are correct,  I misunderstood the data sheet.
your explanation is great and now I actually have an understanding of what is happening.
From the factory it only usues bits 1-3 and parity , i have connected all these and can see them cycing in hal show.
I'm going to try and sit down over the next few days and try to see if i can get this going , thanks for all your help so far.
12 Oct 2023 22:36 #282838 by Trav328
Started working on it this evening , I have a couple questions since I can't find an example to use for reference.
What pins to I connect my encoder in bits to ? I thought it was sense-0/1/2/3 etc but i was mistaken
When I do get that setup how do I setup so it knows what encoder Input = tool 1? , I played with the emco changer comp and it referenced a truth table that you could configure.
13 Oct 2023 21:07 #282941 by Trav328
I now have the atc moving through carousel.
net bit1 carousel.0.sense-0 did the trick , same for parity
It roates the changer but only for a couple tools. And it seems to always take the long way around
Still need to figure out how to tell it what tool is what but were getting somewhere.
14 Oct 2023 10:27 #282976 by andypugh
Do you have "dir=2" in the loadrt carousel line?
Can you _jog_ the carousel in both directions?
14 Oct 2023 12:07 - 14 Oct 2023 12:09 #282985 by Trav328
yes i do
yes i can jog both directions with the jog pins and when i do select a tool using m6t1/2/3/4/ it will move both directions , it just only seems to see a couple pockets even though *carousel.0.current position* is counting pockets up to 7.
also worth noting i do not have bit 8 actually hooked up as this machine did not use it from factory and running the extra wire is not something i really want want do , requires removing the tool changer and all associated wiring.
attached is my hal and ini so you can see what i have going on.
File Name: travis_lathe.ini
File Size:4 KB
File Name: main.hal
File Size:16 KB
Last edit: 14 Oct 2023 12:09 by Trav328.
14 Oct 2023 13:01 #282989 by andypugh
Is it using 0 to 7 for pockets 1 to 8? There is a setting for that. But I am on my phone and can’t remember it.
Time to create page: 0.636 seconds
