ebox.comp for gearbox 2speed
15 Oct 2023 15:02 - 15 Oct 2023 15:04 #283079
by SOLD
ebox.comp for gearbox 2speed was created by SOLD
I have an OKK VM4. It has an 8000rpm spindle motor and 2500ppr encoder 2 speed gear box.
Low speed 1:4 /High speed 1:0.75, gear changing mechanism with air cylinder, takes about 5 seconds to change gear while stationary.
I built a 2 speed Hal with Pncconf. I want the output signal to be sent to the gear selector pin A when the M3S is less than 2000 and check the cylinder position sensor within the ebox.comp file.
I'm a newbie to Halcompile, trying to read what I thought was similar to this post. forum.linuxcnc.org/10-advanced-configura...dle-gearbox?start=20
I have tried to use andypugh's e-box on 2.8.4 but it didn't work as shown in the picture. What caused this? How should I fix it? Or suggest the right thing because I don't have any compiler skills yet.
Another problem: When using G33.1, the number of revolutions of the encoder installed on the spindle motor is not equal to the speed of the tap.
Last edit: 15 Oct 2023 15:04 by SOLD.
15 Oct 2023 17:09 #283081
Replied by andypugh on topic ebox.comp for gearbox 2speed
Can you attach the .comp file? There is something wrong with the syntax on line 2.
The following user(s) said Thank You: SOLD
16 Oct 2023 04:09 - 16 Oct 2023 04:13 #283107
by SOLD
Replied by SOLD on topic ebox.comp for gearbox 2speed
I copied from youCan you attach the .comp file? There is something wrong with the syntax on line 2.
Last edit: 16 Oct 2023 04:13 by SOLD.
16 Oct 2023 13:47 #283124
by chris@cnc
Replied by chris@cnc on topic ebox.comp for gearbox 2speed
There was going something wrong during copy.
Typo in Line 2should be
Typo in Line 2
licence "GPL";
license "GPL";
16 Oct 2023 14:48 #283126
by SOLD
I'll check it. ThankThere was going something wrong during copy.
Typo in Line 2
[/code]licence "GPL"; should be [code]license "GPL";
17 Oct 2023 15:47 #283186
by SOLD
There is a problem at ABSF. What should I do?
17 Oct 2023 21:53 #283195
Ah, yes. I reckon I probably just typed that out (it was 8 years ago) and used the British spelling (because I am)There was going something wrong during copy.
Typo in Line 2
17 Oct 2023 22:00 #283196
(Sorry, this looks like something that I wrote in my lunch break, without access to a Linux machine to check it with).
Try this:
It needs to be fabs, and that needs an include statement.There is a problem at ABSF. What should I do?
Try this:
The following user(s) said Thank You: tommylight, SOLD
18 Oct 2023 05:47 #283208
by SOLD
Thank you for your support.
I compiled it and it worked.
Try this:
18 Oct 2023 08:29 #283218
Does the component actually do what you need it to do, though?
Time to create page: 0.364 seconds
