Configuring LinuxCNC
Advanced Configuration
M52 M53 possible activate in jog mode too?
Thank you received: 73
17 Oct 2023 19:45 #283193
by bkt
not try jet ... but ask if possible use motion.feed-hold and motion.adaptive-speed in manual mode too ... so need activate M52 and M53 outside gcode too I think ....there are a way?
Where find M52 and M53 routine codes?
Thank you received: 1062
18 Oct 2023 07:52 - 18 Oct 2023 07:54 #283216
'motion.feed-hold' has no effect when jogging so maybe try 'motion.jog-inhibit' or 'motion.jog-stop' instead.
M52 also has no effect on jogging. Workarounds for this will depend somewhat on the gui you are using. Gmoccapy offers convenient hal pins to handle jog speed while in 'Axis Gui' you might have to use 'halui.axis.jog-speed' to set the speed and 'halui.axis.L.minus' and 'halui.axis.L.plus' to do the jogging. 'halui.axis.L.analog' might also be of interest as that will allow to scale the jog speed between -1..1.
Note that in some guis (like 'Axis') these halpins will be overridden by the jog buttons in the gui.
linuxcnc.org/docs/html/man/man1/halui.1.html
Last edit: 18 Oct 2023 07:54 by
Aciera.
The following user(s) said Thank You:
bkt
Thank you received: 4803
18 Oct 2023 10:52 #283223
I don't think that there is a way, as jogging / manual uses a different motion planner than coordinated mode.
bkt
18 Oct 2023 14:01 #283234
by bkt
motion.feed-hold .... just try work perfect in joint jog mode, and world jog mode .... work perfect ... think no problem to work in gcode too.
motion.adaptive-feed .... not work .... but maybe can work .... not find M52 and M53 code so not understand what they do and how they do it ....
18 Oct 2023 14:32 #283236
Hm, not sure what you are doing but I tried it also and for me it sure does not work on Version 2.9. Neither joint or axis jog is affected by motion.feed-hold and since jogging uses a different planner I'm not sure how it could.
18 Oct 2023 19:16 #283248
by bkt
maybe because you use some standard linuxcnc gui .... not sure about version data but I've a 2.9 linuxcnc, and use a c++ gui .... exchange signal and value is trought nml, and pin value on shemem ... for these reason think I have these effect that you not have .... and for that reason think can try to have some result on M52 code when discover where is placed on (folder and name file) .... maybe not but if not see it is impossible to discover ...
Any how I try to limit velocity near singularity issue zone .... for now I drive the change using a pin from my kinematics that check when i reach singularity zone and halui.axis.jog-speed pin .... in these way everytime "enter" in "danger" zone can set a lower velocity .... but logic of mechanism is not clean so try to do somethings more clear and clean only for that pourpose ....
Aciera
18 Oct 2023 21:18 - 18 Oct 2023 21:19 #283255
by bkt
@andyPugh ..... mmmm ... you think switchkins in joint mode not use same motion planner than coordinate mode? curious ....
Last edit: 18 Oct 2023 21:19 by
bkt.
19 Oct 2023 07:21 #283280
What he meant is that _jogging_ does not use the same planner.
Switchkins does not change the planner.
19 Oct 2023 15:02 - 19 Oct 2023 17:57 #283301
by bkt
Ok understand ... obviusly switchkins not change plan .... but drive joint and axis too ... because for drive (or regulate velocity) of joint need to use joint .... I think can work in jogging mode too .... HOW??? I think if can study M52 script (that not find probabily because name in different way) can understand if my ideas was wrong or not ....I know my English is pitiful, be patient... I'm also old
Last edit: 19 Oct 2023 17:57 by
bkt.
19 Oct 2023 17:59 - 19 Oct 2023 18:02 #283309
by bkt
Any how I discove today MDI command (trough shell) develop from andyPugh? real thanks for that ... very fine and helpful (in general for uses Lcnc ... not for these thread).
Last edit: 19 Oct 2023 18:02 by
bkt.
Time to create page: 0.179 seconds
