P1A-S pendante moving Options
23 Oct 2023 14:10 #283602
by holziCNC
P1A-S pendante moving Options was created by holziCNC
Hello everybody,I have installed and included an iMach controller in my LinuxCNC configuration to control my milling machine.It's working well, except that the velocity and continuous mode only work when the machine is not homed.Do you have any suggestions or solutions?
23 Oct 2023 15:29 #283608
looking at your 'vc-p1as.hal' I don't see any pins for axis jogging so maybe try to change this:
with this:
Replied by Aciera on topic P1A-S pendante moving Options
Not sure but I presume you mean jogging only works when the machine is not homed.t's working well, except that the velocity and continuous mode only work when the machine is not homed.
net jog.0.cont-plus vc-p1as.jog.0.plus => halui.joint.0.plus
net jog.0.cont-minus vc-p1as.jog.0.minus => halui.joint.0.minus
net jog.1.cont-plus vc-p1as.jog.1.plus => halui.joint.1.plus
net jog.1.cont-minus vc-p1as.jog.1.minus => halui.joint.1.minus
net jog.2.cont-plus vc-p1as.jog.2.plus => halui.joint.2.plus
net jog.2.cont-mimus vc-p1as.jog.2.minus => halui.joint.2.minus
net jog-speed vc-p1as.jog.velocity => halui.axis.jog-speed halui.joint.jog-speed
with this:
net jog.0.cont-plus vc-p1as.jog.0.plus => halui.joint.0.plus halui.axis.x.plus
net jog.0.cont-minus vc-p1as.jog.0.minus => halui.joint.0.minus halui.axis.x.minus
net jog.1.cont-plus vc-p1as.jog.1.plus => halui.joint.1.plus halui.axis.y.plus
net jog.1.cont-minus vc-p1as.jog.1.minus => halui.joint.1.minus halui.axis.y.minus
net jog.2.cont-plus vc-p1as.jog.2.plus => halui.joint.2.plus halui.axis.z.plus
net jog.2.cont-mimus vc-p1as.jog.2.minus => halui.joint.2.minus halui.axis.z.minus
net jog-speed vc-p1as.jog.velocity => halui.axis.jog-speed halui.joint.jog-speed halui.axis.jog-speed
Time to create page: 0.171 seconds
