Lcnc 2.10 -- halcompile for kins
30 Oct 2023 09:08 #284106
by bkt
Replied by bkt on topic Lcnc 2.10 -- halcompile for kins
so now not try to install my kins ... only modify scarakins and compile again linuxcnc-dev run in place install ..... after copy scarakins.so on usr/linuxcnc/module ..... in these way i have my app starting but ... surprize .... I have these error:
if put loadrt scarakins after EMCMOT loadrt .... but if try at inverse order the error become:
testPc@mark28:~$ /usr/bin/linuxcnc '/home/testPc/linuxcnc/configs/scaraSwitch.cld/scaraSwitchTest.ini'
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/testPc/linuxcnc/configs/scaraSwitch.cld'
Machine configuration file is 'scaraSwitchTest.ini'
check_config: Unchecked: [KINS]KINEMATICS={scarakins coordinates=xyzabc}
Starting LinuxCNC...
Note: Using POSIX realtime
task: machine: 'SCARA-JA-switch' version 'unknown'
emc/task/taskclass.cc 168: can't load tool table.
Found file(REL): ./scaraSwitchTest.hal
creating ladder-state
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: kinematicsSwitch
./scaraSwitchTest.hal:17: waitpid failed /usr/bin/rtapi_app motmod
./scaraSwitchTest.hal:17: /usr/bin/rtapi_app exited without becoming ready
./scaraSwitchTest.hal:17: insmod for motmod failed, returned -1
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
LinuxCNC terminated with an error. You can find more information in the log:
/home/testPc/linuxcnc_debug.txt
and
/home/testPc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
task: machine: 'GC-SCARA-JA-switch' version 'unknown'
!!! switchkins-type 0 is scarakins
userkKinematicsSetup:
emc/kinematics/userkfuncs.c <xyzabc> max_joints=6 allow_duplicates=0
Init tmp dir=/tmp/classicladder_tmp_Q0gLWs
Gtk-Message: 10:06:20.580: GtkDialog mapped without a transient parent. This is discouraged.
ManagerDisplaySections(): init...
ManagerDisplaySections(): added Prog1...
select... before=-1 scan=0
void MainWindow::changeUserGui() hey ci sono ... 6
void MainWindow::changeUserGui() questa è finita ... 6
int set_pin_FLOAT_calc(float, QString) sig velControl is not writable or not exist ... type is: "ERROR" and (sig>0 no good) sig->writers = 1
int set_pin_FLOAT_calc(float, QString) sig eJogSpeed is not writable or not exist ... type is: "ERROR" and (sig>0 no good) sig->writers = 2
MainWindow::MainWindow(QWidget*) controlliamo stato cnc ... 0x55a32defb860
/usr/bin/linuxcnc: riga 957: 17838 Errore di segmentazione (core dump creato) $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
task: 0 cycles, min=0.000005, max=0.013697, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.010000s)
INFO CLASSICLADDER- GUI scala chiusa. Esecuzioni in tempo reale fino alla chiusura dell'HAL
scale: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
mult2: not loaded
sum2: not loaded
30 Oct 2023 09:44 #284109
Replied by andypugh on topic Lcnc 2.10 -- halcompile for kins
Does the run-in-place version run?
And do both versions run wuth an unmodified kins (trivkins, for example)
30 Oct 2023 10:21 - 30 Oct 2023 19:39 #284111
by bkt
Axis gui works but my c++ gui shows some pins not writable when they should be....I think that's why my c gui throws these errors....think about these one (previous error become from my terminal, when try to launch QT myapp gui):
thse still valid ....
all other part of post is cancell because erroneus consideration ...
Last edit: 30 Oct 2023 19:39 by bkt.
30 Oct 2023 10:49 - 30 Oct 2023 19:37 #284115
by bkt
think problem maybe located here .....
these code read 2.8Lcnc and 2.9 2020 Lcnc (dev version not master one) .... and now seems not capable to write float signal like attachment on previous post ....but just try other things .... see hal_cmd_20a1 not found!!!! (--- whit axis gui ---)there are some other that no go ....
just try axis gui with .deb package install and run in place install ... same result ... motor go and all works ok.
So only things not go is my app ..... I have some problem with carpenter.so .... but not sure these causes that problem ...
actually when start Axis Gui from terminal obtain these error:
these one is not know .... do I have to worry?
testPc@mark28:~$ linuxcnc
Machine configuration directory is '/home/testPc/linuxcnc/configs/KeepTestC.cld'
Machine configuration file is 'keepTest.ini'
check_config: Unchecked: [KINS]KINEMATICS={scarakins coordinates=xyzc}
Found file(REL): ./TESTkeepTest.hal
identityKinematicsSetup: coordinates:xyzc
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Z
Joint 3 ==> Axis C
emc/kinematics/userkfuncs.c <xyzc> max_joints=4 allow_duplicates=0
Init tmp dir=/tmp/classicladder_tmp_FM2qD0
Gtk-Message: 20:33:23.078: GtkDialog mapped without a transient parent. This is discouraged.
note: MAXV max: 280.000 units/sec 16800.000 units/min
note: LJOG max: 280.000 units/sec 16800.000 units/min
note: LJOG default: 5.000 units/sec 300.000 units/min
note: AJOG max: 90.000 units/sec 5400.000 units/min
note: AJOG default: 30.000 units/sec 1800.000 units/min
waiting for s.joints<0>, s.kinematics_type<0>
note: jog_order='XYZC'
note: jog_invert=set()
Last edit: 30 Oct 2023 19:37 by bkt.
17 Nov 2023 13:08 #285740
There is a known race condition in 2.10, this might be causing the "command 30 timeout"
github.com/LinuxCNC/linuxcnc/issues/2700
The following user(s) said Thank You: bkt
19 Nov 2023 17:53 #285927
by bkt
thnks .. actually switch to 2.9.1 that have not that problem .... I investigate more during snow holiday when try to upgrade to debian .... and try to upgrade at to newest kernel
