- Configuring LinuxCNC
- Advanced Configuration
- Raise an error message on loading pure python remappped gcode
10 Nov 2023 08:41 #285014
I know how to raise an interpreter error if task==1 (ie during actual gcode execution).
This will end code execution with an error message 'my error message here' in the gui:
What I would like to do now is to raise an error message when the gcode is loaded (ie task == 0):
This code will print 'Error -> aborting G68.2' to the terminal but no error is displayed in the gui:
So I assume that emccanon.CANON_ERROR does not work for the interpreter used for creating the preview.
Is there is a way to raise an error message in the standalone interpreter from a python remap?
if self.task == 1:
if <some statement is true>:
print('Error -> aborting G68.2')
emccanon.CANON_ERROR( 'G68.2 ERROR: 'my error message here' )
yield INTERP_EXIT
else:
if self.task == 0:
yield INTERP_EXIT
else:
10 Nov 2023 14:52 - 10 Nov 2023 14:57 #285029
Replied by Aciera on topic Raise an error message on loading pure python remappped gcode
Found a solution here:
www.forum.linuxcnc.org/24-hal-components...xcnc?start=10#208679
I created a helper component with an IO pin 'twp_error' that gets written to from my python remap and then cleared in the helper component:
try:
while 1:
if h['twp_error'] == 0:
pass
elif h['twp_error'] == 1:
c.error_msg('G68.2 ERROR: TWP already active!')
elif h['twp_error'] == 2:
c.error_msg('G68.2 ERROR: Cannot define TWP from active G59.2 or G59.3 offsets.')
elif h['twp_error'] == 3:
c.error_msg("G68.2 ERROR: Can't enable TWP with G91 active!")
h['twp_error'] = 0
Last edit: 10 Nov 2023 14:57 by Aciera.
10 Nov 2023 15:26 #285031
btw.
I did also try to use the c.error_msg('..') command in the remap itself but this resulted in a very noticeable delay until the message was actually displayed in the gui. The method with the hal pin and the helper component displays the messages instantly.
10 Nov 2023 19:35 #285042
Replied by cmorley on topic Raise an error message on loading pure python remappped gcode
apparently you can just return a string for an error, but I haven't tried it.
Time to create page: 0.206 seconds
