- Configuring LinuxCNC
- Advanced Configuration
- Does a machine configuration made for Bookworm run in Buster?
07 Dec 2023 08:31 #287420
by SvenH
As my newly installed Bookworm linuxcnc will not run the spindle (link below), can I just add the configuration files to a fresh Buster install or will it need some converting?
Thread on spindle not running:
forum.linuxcnc.org/10-advanced-configura...uangyang-vfd?start=0
07 Dec 2023 09:31 #287422
Replied by andypugh on topic Does a machine configuration made for Bookworm run in Buster?
Yes, it should just work. The configs are completely agnostic about the underlying OS. 2.9.x runs on both Buster and Bookworm.
07 Dec 2023 13:03 #287441
But see my reply to the other thread for an alternative solution.
You seem to be mis-identifying the likely cause, it isn't because you have moved from Buster to Bookworm, but because you have updated from 2.7 to 2.8+ and the spindle HAL pin names have changed to support multiple spndles.
