caxis.comp - spindle reverse
11 Dec 2023 19:58 #287878
by spumco
caxis.comp - calling @andypugh was created by spumco
@Andy,
As you might have noticed, I've resurrected NoJo's thread regarding the work you and he (and others) did on his live-tool c-axis DIY lathe in 2021. My own lathe is nearing completion - axes & spindles are moving reasonably well - and it's time to work on the C-axis function.
While waiting for a reply from him, I've been re-reading the multiple threads and trying to digest everything - specifically caxis.comp. If you don't mind revisiting the topic, I have a few questions you may be able to clarify - perhaps better than NoJo as you appeared to be the primary author.
NoJo's last posted config (5/2023) looks like he added a switchkins function, via G12.1/13.1 and some m-code bash commands, to your basic caxis.comp component.
However, the last caxis.comp file you posted (5/30/2021) looks like it doesn't contain any reference to polar interpolation. If my thread-reading skills aren't complete garbage, it appears that the control scheme you intended was:
Assuming I'm not way off base, here's my question, or at least my concern...
My lathe is a gang-tool setup, and I know I'll (eventually) have tools that are front, back, M3 as well as M4. I'm concerned that if I have an M3 tool followed by an M4 tool, each spindle direction change will need to wait for the C-axis to return to the last position.
Is there any way to stop the automatic C-axis mode resuming after a spindle-mode stop? Perhaps a modification of caxis.comp where some pins are added that can be tied to motion.digital-in pins or M-codes that stop the C-axis mode from forcing a re-home until triggered in g-code?
I guess what I want is a spindle with non-automatic C-axis capability...
Am I even in the right ballpark?
Thanks,
R
- lathe turned on
- all axes homed, including C-axis
- lathe is in C-axis mode until a spindle command is given
- spindle command executed
- PID switch handled by caxis.comp
- spindle stopped
- Resume C-axis mode automatically
- switch back to c-axis PID
- C-axis moves to last position prior to spindle engagement
- Does not need to unwind more than 360 degrees
Thanks,
R
The following user(s) said Thank You: COFHAL
14 Dec 2023 11:49 #288122
Is that a major problem? I think I would suggest trying it out first to see if you even notice.
(Also, if the spindle remains on, it will probably just reverse without going back into C mode)
Replied by andypugh on topic caxis.comp - calling @andypugh
[*]C-axis moves to last position prior to spindle engagement
[*]Does not need to unwind more than 360 degrees
14 Dec 2023 12:38 #288123
by spumco
Wise suggestion, as usual. I'll have a go at it and see if it behaves.
Replied by spumco on topic caxis.comp - calling @andypugh
- Is that a major problem? I think I would suggest trying it out first to see if you even notice.
07 Jan 2024 04:53 - 07 Jan 2024 04:55 #290045
by spumco
Replied by spumco on topic caxis.comp - spindle reverse
@Andy,
Thank you - M3 to M4 works as you suspected. Spindle reverses without returning to the last c-axis position.
At M5 it stops and returns to last c-axis position before spindle mode.
(sorry for fiddling with the thread title)
Last edit: 07 Jan 2024 04:55 by spumco.
