Axis letters vs joint numbers - does the order matter?
19 Dec 2023 15:03 #288587
by spumco
TLDR:
Do I need to change the order of some/all the axis/joint numbers in INI? If so, to what?
Does a switchable userkins need a default configuration (i.e. when in cartesian mode)? If so, where is that defined?
Longer version:
Does the order of axes letters & joint numbers in INI matter? I installed a user kinematics module and during initial testing got a confusing error.
Specifically, commanding G0 C90 resulted in a "Joint 2 limits would be exceeded" error... but I've defined C-axis as Joint 3. What gives?
Now I'm wondering if I need to change the order of axes/joint in my INI file. Here's a summary of what I've got, both in INI and physically:
Physical components:
I don't really understand the userkins.comp file, having borrowed it from NoJo. Nor do I understand where to define the 'default' KINS arrangement when polar interp mode is off.
Axis letters vs joint numbers - does the order matter? was created by spumco
TLDR:
Longer version:
- X-axis
- Traditional axis, nothing strange
- Z-axis
- V-axis
- Separate slide mounted to lathe headstock. Used for parting tool, much like some Hardinge chuckers.
- I could define this as an extra_joint, but I want CSS while parting and I think I need it defined as an axis to get this feature.
- C-axis (main spindle)
- Servo spindle motor, both spindle and c-axis mode
- using caxis.comp to switch between modes
- C-axis (sub-spindle, not yet implemented)
- hoping to duplicate the main spindle dual-mode here as well
- [DISPLAY]
- GEOMETRY = not defined
- [TRAJ]
- COORDINATES = XZVC
- [KINS]
- KINEMATICS = polar_userkins
- [AXIS X]
- [JOINT 0]
- [AXIS Z]
- [JOINT 1]
- [AXIS V]
- [JOINT 2]
- [AXIS C]
- [JOINT 3]
19 Dec 2023 15:16 #288588
Replied by andypugh on topic Axis letters vs joint numbers - does the order matter?
The mapping of axes to joints is defined in the kinematics file (possibly as a parameter passed to the kinematics file as it is loaded)
The position in the INI is not relevant. Your INI could be
Axis X
Joint0
AxisY
Joint1
Or
Axis X
Axis Y
Axis Z
Joint0
Joint1
Joint2
Or even, of you wanted,
Joint3
Joint1
Joint0
Axis C
Joint2
Axis X
Axis Z
Axis Y
The components search the INI for the information that they require when they require it.
Axis X
Joint0
AxisY
Joint1
Or
Axis X
Axis Y
Axis Z
Joint0
Joint1
Joint2
Joint3
Joint1
Joint0
Axis C
Joint2
Axis X
Axis Z
Axis Y
19 Dec 2023 16:03 #288591
by spumco
Replied by spumco on topic Axis letters vs joint numbers - does the order matter?
I don't see any parameters being referenced in the kinematics file (i.e. INI references).
The kinematics file has this in it:
And a little later on:
Does that mean kinematics file is using the default as described in KINS man page when switchkins_type = 0?
And maybe NoJo's kinematics file needs to be edited for my particular configuration?
KINEMATICS_TYPE kinematicsType()
static bool is_setup=0;
if (!is_setup) polar_userkins_setup();
return KINEMATICS_IDENTITY;
if (switchkins_type == 1)
// G12.1 mode : do polar to cartesian conversion
angle_rad = j[2] * M_PI / 180.0;
radius = j[0] - tool_offset;
pos->tran.x = (radius * cos(angle_rad)) + tool_offset;
pos->c = -(radius * sin(angle_rad)); // ref comment in inverse kinematics
else
pos->tran.x = j[0];
// on an exit from polar, am adjusting the pos->C and j[2] values so that the max distance back to zero
// will be between 0 and 360deg. As in polar mode, we may have clocked up several revolutions of C, which
// means if did not do this setp, would unwind all these positions. The method is derived from what the
// caxis component does on a transition from spindle to caxis mode. Note that the j[2] value is updated
// in the caxis component as cannot write associated net pin here as that pin is written to in caxis.
if (prev_switchkins_type_fwd != switchkins_type)
offset = round(*haldata->spindle_revs);
pos->c = (*haldata->spindle_revs - offset) * 360;
else
pos->c = j[2];
prev_switchkins_type_fwd = switchkins_type;
pos->tran.z = j[1];
pos->b = j[3];
// unused coordinates:
pos->tran.y = 0;
pos->a = 0;
pos->u = 0;
pos->v = 0;
pos->w = 0;
return 0;
19 Dec 2023 17:36 #288604
Replied by Aciera on topic Axis letters vs joint numbers - does the order matter?
For example, this means 'Axis X = Joint 0'
This one 'Axis C = Joint 2'
And so on.
pos->tran.x = j[0]
pos->c = j[2];
And so on.
19 Dec 2023 17:43 #288605
So this would be the setup from the kinematic:
Joint 0 > axis X
Joint 1 > Axis Z
Joint 2 > Axis C
Joint 3 > Axis B
Joint 0 > axis X
Joint 1 > Axis Z
Joint 2 > Axis C
Joint 3 > Axis B
19 Dec 2023 18:09 #288606
by spumco
That makes so much more sense now.
Assuming I'll have to edit the comp and re-do halcompile, right?
Or rename my joints/axes to match the comp?
19 Dec 2023 23:45 #288626
YesAssuming I'll have to edit the comp and re-do halcompile, right?
05 Jan 2024 04:01 #289826
by spumco
Back on this after the holidays, but still having issues.
I've edited my INI & HAL files to match the polar_userkins.comp scheme. i.e. C-axis is now joint 2, and all the hal connections have been changed to joint.2.xxx pin names.
HOME_USE_INDEX = 1 for joint 2 in INI
Maybe someone could look over my HAL file(s) and see if there's something obvious? 03SPINDLE_MAIN.hal has both the spindle and C-axis/joint stuff in it. Using the same comps as posted earlier.
Thx
- On startup, no immediate errors.
- Can start the spindle with M3/M4 and stop it with M5.
- When spindle is started, caxis.pid-enable turns off in halshow (as I believe is intended in caxis.comp)
- As soon as spindle is off, caxis.pid-enable turns on (again, as intended - I think)
- Attempt to home C-axis/joint 2 - spindle rotates at an appropriate speed (~60rpm), but gets an ferror after a couple of rotations
- joint.2.index-enable & pid.c0.index-enable do NOT get set when homing starts
- note - INI ferror set to 1000 for testing
- Machine turns off
- Upon re-enable it immeidately continues to attempt homing
- Must trigger encoder.04.reset to 'clear' everything
- If I manually set the encoder index-enable (sets)
- encoder.04.index-enable, joint.2.index-enable, and pid.c0.index-enable all turn on
- When it starts homing the index-enable(s) all go off when the index signal passes, but this doesn't appear to register with the homing process and it continues rotating until the ferror.
Thx
Time to create page: 0.210 seconds
