KERNEL 6.6.7 (improved latency)
23 Dec 2023 08:28 - 07 Jan 2024 20:22 #288870
by Mecanix
* Custom driver installations, if any, will require re-installation.
** Compiling took 3.5hrs on a i7 3.2Ghz
KERNEL 6.6.7 (improved latency) was created by Mecanix
### DEPs
$ sudo apt update && sudo apt upgrade
$ sudo apt install -y build-essential bin86 libncurses5-dev pkg-config libssl-dev dwarves bison flex gnupg libelf-dev libssl-dev wget qtbase5-dev debhelper rsync git
### KERNEL 6.6.7
$ git clone -b v6.6 --depth 1 https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git linux-6.6
$ wget https://mirrors.edge.kernel.org/pub/linux/kernel/v6.x/patch-6.6.7.xz
$ wget https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/6.6/patch-6.6.7-rt18.patch.xz
$ unxz patch-6.6.7.xz
$ unxz patch-6.6.7-rt18.patch.xz
$ cp patch-6.6.7 patch-6.6.7-rt18.patch linux-6.6
$ rm patch-6.6.7 patch-6.6.7-rt18.patch
$ cd linux-6.6
$ cat patch-6.6.7 | patch -p1
$ cat patch-6.6.7-rt18.patch | patch -p1
$ git add *
$ make xconfig
(Save and Exit gui)
$ scripts/config --disable SYSTEM_REVOCATION_KEYS
$ scripts/config --disable DEBUG_INFO
$ scripts/config --enable DEBUG_INFO_NONE
$ scripts/config --set-str SYSTEM_TRUSTED_KEYS ""
$ make -j$(nproc) deb-pkg LOCALVERSION=-linuxcnc
(as per Rodw's advice for all cores. See below post.)
$ cd ..
### INSTALL
$ sudo dpkg -i linux-image-6.6.7-rt18-linuxcnc_6.6.7-gffc253263a13-1_amd64.deb
$ sudo dpkg -i linux-headers-6.6.7-rt18-linuxcnc_6.6.7-gffc253263a13-1_amd64.deb
$ sudo reboot
Last edit: 07 Jan 2024 20:22 by Mecanix.
23 Dec 2023 10:06 #288879
Replied by andypugh on topic KERNEL 6.6.7 (improved latency)
Are you sating that this gives better latency than the pre-packaged 6.10-rt kernel?
23 Dec 2023 10:47 #288889
Replied by rodw on topic KERNEL 6.6.7 (improved latency)
Andy, yes, I expect so. Just compliling the kernel from pristine sources improves latency over the debian ones. ANd latency has been observed as improving with each iteration of the pristine RT patch.
@Mechanix, I7's can have a lot more than for cores. Mine has 20. check with echo $(nproc)
Use make -j$(nproc) to use them all
23 Dec 2023 10:47 #288890
by Mecanix
Replied by Mecanix on topic KERNEL 6.6.7 (improved latency)
Noticed a 30% enhancement over the turtle-slow pre-packed 6.10 on an older workstation (2 cores). That's powering a laser cutter and a 3ax mill, both still over parport and so I need all I can get. However on the i7 (8 cores) powering the 2ax lathe and a 4ax mill (gigabyte ethernets) not-so-much difference.
23 Dec 2023 10:49 #288891
That answers my question. use make -j8 next time to save a lot of time.
The following user(s) said Thank You: Mecanix
23 Dec 2023 11:35 - 23 Dec 2023 11:39 #288895
by Mecanix
@Rodw
Given your advanced knowledge (I think you're the author of this kernel compiling routine if I recall) you would certainly know how to tweak those linux box to the bones and nerves?? All dirty laundry on core 0, the remaining 7cores for the cookin. Any comments?
$ sudo nano /etc/default/grub
#GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX_DEFAULT="skew_tick=1 rcu_nocb_poll rcu_nocbs=1-7 nohz=on nohz_full=1-7 kthread_cpus=0 irqaffinity=0 isolcpus=managed_irq,domain,1-7 intel_pstate=disable nosoftlockup tsc=nowatchdog"
$ sudo update-grub
$ sudo update-grub
Last edit: 23 Dec 2023 11:39 by Mecanix.
23 Dec 2023 12:40 #288902
yeh, I thought the script looked famiiar. Saved me the need to update it
I have not done much other than isolcpus.
If you are using mesa ethernet cards latency is no longer the limiting factor. Network latency is the issue.
network latency has been improving with each kernel version.
With mesa, the next thing to look at is to locate the IRQ (Interrupt Request) used by the NIC.
set Isolcpus=7 wil put the servo thread on core 7
Then you can set the irq affinity to also be on core 7 so the Real time stuff is al together
This can be set on the command line and its pretty easy to find resouces with google
23 Dec 2023 12:43 #288903
I might add that the servo thread only ever runs on one core. Whilst latency improves with adding additional isolated CPUS, I suspect its eye candy.
htop shows cpu useage per kernel which is interesting to watch
23 Dec 2023 13:38 - 23 Dec 2023 13:39 #288907
by Mecanix
Maintaining 4 machine-tools, involving two different kind of interface (parport & eth), not to mention 3 different computers and hardware ain't for the faint of heart. One day this will all need to be consolidated but until then it makes it all very much fun and for good learning! Appreciate the IRQ heads up, I'll focus on that part and see if I can optimize from there.
Last edit: 23 Dec 2023 13:39 by Mecanix.
23 Dec 2023 15:14 #288918
by chris@cnc
Is the command to use all available cores.
Replied by chris@cnc on topic KERNEL 6.6.7 (improved latency)
make -j `nproc`
Time to create page: 0.206 seconds
