Halcompile problem. Linuxcnc 2.9.2 on debian 11
26 Dec 2023 09:30 #289077
by Henk
Halcompile problem. Linuxcnc 2.9.2 on debian 11 was created by Henk
Hi.
After upgrading to 2.9.2 from 2.8.4, I had to upgrade to debian 11 as well because I had issues with my custom gladevcp panel.
Now trying to compile two of my comps which worked well on debian 10 and 2.8.4 I found that halcompile doesn't show any messages after running sudo halcompile --install compfile.comp.
absolutely nothing. Even after creating a deliberate syntax error. Still nothing.
any hints?
Where else can I see the compiler messages?
any hints?
26 Dec 2023 09:42 #289078
Replied by rodw on topic Halcompile problem. Linuxcnc 2.9.2 on debian 11
try; sudo apt install linuxcnc-uspace-dev
26 Dec 2023 11:20 #289084
by Henk
Replied by Henk on topic Halcompile problem. Linuxcnc 2.9.2 on debian 11
Hi Rodw.
tried that now. Feedback from terminal is linuxcnc-uspace-dev is already the latest version
26 Dec 2023 11:26 #289085
by Henk
Please ignore. If you get the command right, it works as expected. Forgot the --install ...
