Issue calling cutom o-word from Python M6 remap script
27 Dec 2023 17:38 #289187
by tom_no
Issue calling cutom o-word from Python M6 remap script was created by tom_no
As part of configuring my ATC, I'm trying to call a custom m-code (m301.ngc) from remap.py M6 remap-script.
Is this at all possible?
My custom M-codes all work from MDI and is intended to handle all machine movements related to the ATC. M300 to stop and reset spindles M301 to pick tool from pockets, M302 to place tool in pocket.
remap.py runs as intended in "dry mode", but does not run the m-code.
Following lines in remap.py:
Struggling to troubleshoot this issue, so any an all input will be greatly appreciated!
Kind regards
TomE.
gives this output in terminal window:print("Executing command M301 P%d" % selectedpocket)
if dry_run == False:
self.execute("M301 P%d" % selectedpocket)
Executing command M301 P3
is_callable(oword.m301) = FALSE
is_callable(oword.m300) = FALSE
remap_finished: got -8 - not in cblock.remappings!
Kind regards
TomE.
28 Dec 2023 12:04 #289241
by tom_no
Replied by tom_no on topic Issue calling cutom o-word from Python M6 remap script
After re-reading bevins' lesson learned on Python remap I suspect my problem to be related to the interpreter not being able to run several scripts in a row. IE: TopLevel.py -> remap.py -> M30x.NGC is "a bridge too far".
Bit the bullit and moved the M30x code into remap.py as functions. Seems to work, and I'm moving forward.
07 Jan 2024 22:41 #290153
Replied by andypugh on topic Issue calling cutom o-word from Python M6 remap script
I think that the problem is that you can't "MDI"G0code commands inside a Python remap (as the system is in "Auto" mode. Basically the interpreter is in-use.
The answer is generally to use the Python interface or canonical function calls.
The latter are not particularly well documented.
But this search on github will show some examples:
github.com/search?q=repo%3ALinuxCNC%2Fli...n&type=code&l=Python
for example emcconon.STRAIGHT_FEED and emccoanon.STRAIGHT_TRAVERSE
15 Jan 2024 20:14 #290790
by tom_no
Thanks Andy! I'll try converting to canoncical function calls where I'm stuck. As per now the M6 script is running as expected, only need to add check that all tool pockets are retracted before shutting ATC cover to avoid expensive collissions.
