- Configuring LinuxCNC
- Advanced Configuration
- 1st move after using eoffset violates machine acc and vel limits...
02 Jan 2024 16:36 - 03 Jan 2024 14:21 #289575
by Henk
HI. I ran into an issue with a new machine config where i use eoffsets as part of the tool change operation. It seems that the first move after a toolchange violates the machine acceleration and velocity limits. If i run the same code without the M6 T14 line, it works as expected. I verified this by looking at a halscope plot of joint3.position-cmd, which clearly shows a step change of 85 degrees at line 12 (G30 IS AT B=90)
The background is complicated, but here are some details that i think contributes to this issue.
Why do i use external offsets during toolchange? Because of this issue: github.com/LinuxCNC/linuxcnc/issues/246#issuecomment-423049528
And i need to move the Z axis of the machine to remove and insert tools while doing a toolchange. I wrote a custom comp to handle the toolchange, which at the right state enables eoffset on the Z axis. comp attached. The comp also handles the orientation, since m6 cancels orient (verified in a sim config) If there are any other details required to help me understand this issue, please let me know, for now i am not sure which way to go apart from adding a workaround in my cam post by adding small incrimental moves after toolchanges. Ini and .comp file attached (note that i set the ferror limits to large values while still trying to solve this issue) Thanks and Happy new Year! Henk
(DRILL2 2)
N1 g54
N2 g64p0.02
N3 M9
N4 M1
N5 G30
N6 M101 ;high gear
N7 G4 P1
N8 T14 M6
N9 S1500 M3
N10 G54
N11 G54
N12 G0 B5. C-90.
N13 m2
Last edit: 03 Jan 2024 14:21 by Henk. Reason: fixed hyperlink
03 Jan 2024 14:31 #289661
Replied by andypugh on topic 1st move after using eoffset violates machine acc and vel limits...
External offsets are _meant_ to stay inside machine limits, so this particular case sounds like a bug, and should probably be reported as such.
04 Jan 2024 10:00 #289748
by Henk
Replied by Henk on topic 1st move after using eoffset violates machine acc and vel limits...
HI Andy
I was also convinced that this is a bug, but not so sure anymore.
I set up a sim config and wrote a simple comp to offset the z axis during a toolchange, and move it back again before signalling tool-changed.
I dont see the same behaviour as on my actual machine, and it works as it is supposed to work.
puzzled, have to think about this a bit more...
