Spindle speed limited
16 Jan 2024 18:03 #290887
by eduard
Replied by eduard on topic Spindle speed limited
I solve the limitation of the controlword. Omron Ethercat module has an individual PDO for frequency reference, so I can control form 0-1000Hz the spindle.
But this creates another problem, I do not have rpm anymore. Somehow I have to transform 0-1000Hz to 0-60.000rpm, becouse now With M3 I have frequency instead of rpm.
There is solution for this in lcnc or I have to write it myself? If so, where?
16 Jan 2024 18:39 - 16 Jan 2024 18:42 #290892
by 0x2102
Replied by 0x2102 on topic Spindle speed limited
You can scale in your generic driver XML.
Example: ( assumes 1000Hz = 60000rpm) or 1/60 = 0.016667
60000rpm will send 1000 to your PDO.
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscommand" halType="float" scale="0.016667"/>
or you can use the RT comp scale:
linuxcnc.org/docs/html/man/man9/scale.9.html
Last edit: 16 Jan 2024 18:42 by 0x2102.
16 Jan 2024 19:36 - 16 Jan 2024 19:42 #290901
by eduard
Thanx!
Where do you find the xml documentation?
Ok, I understand, I have to put the scale command in frequency reference line.
The scaling is clear, and good idea to scale the hz to rpm.
Last edit: 16 Jan 2024 19:42 by eduard.
Time to create page: 0.119 seconds
