5-axis config - Tool change not working
26 Jan 2024 18:34 #291674
by tommy
5-axis config - Tool change not working was created by tommy
What could be the reason that after T100M6G43 the following popup window doesn't show up:
Tool table looks like this:
As a reference I have configs/sim/axis/vismach/5axis/bridgemill, in which are two lines in INI that might be related to this problem (or not), For first line I'm receiving error on startup of Lcnc:
HALFILE = LIB:basic_sim.tcl -no_make_ddts -no_simulated_home -no_sim_spindle
HALCMD = net :kinstype-select <= motion.analog-out-03 => motion.switchkins-type
29 Jan 2024 13:27 - 29 Jan 2024 13:28 #291888
by tommy
Replied by tommy on topic 5-axis config - Tool change not working
I came to a point that Tn M6 G43 or even G43 Hn, takes tool from tool table (TLO Z: 100), but Tool Center Point doesn't shift form pivot_length to tool tip, so tool length is still not adopted by kinematics.
I checked this simply by jog B-axis for example where you can clearly see around which point it tilts.
In preview and simulation it shows as it works correctly, but on real machine it is not.
Last edit: 29 Jan 2024 13:28 by tommy.
29 Jan 2024 15:31 #291895
Replied by Aciera on topic 5-axis config - Tool change not working
The bridgemill kinematics expects the tool-z offset to be added to the pivot-length. In the sim config this is done in '5axisgui.hal':
If you do not use the vismach simulation window then remove this line from the above:
# compute pivot-length needed for 5axiskins
# according to gui pivot_len and tool z offset
loadrt sum2 names=pivotsum
addf pivotsum servo-thread
net :gui-pivot-len <= 5axisgui.pivot_len
net :gui-pivot-len => pivotsum.in0
net :tool-len <= motion.tooloffset.z
net :tool-len => pivotsum.in1
net :tool-len => 5axisgui.tool_length
net :pivot-len <= pivotsum.out
net :pivot-len => 5axiskins.pivot-length
30 Jan 2024 13:19 #291979
by tommy
Exactly what was missing in my config! Thank you!
Time to create page: 0.072 seconds
