Calibration of screw variation along axis
- smc.collins
- Thank you received: 109
17 Feb 2024 04:18 #293573
by smc.collins
Calibration of screw variation along axis was created by smc.collins
Is there a tutorial on how to setup lead screw calibration ? Or surface mapping offset etc ?
I'm getting service call as soon as i can to laser measure and calibrate my 2 converted machines
I searched but didn't find anything conclusive
17 Feb 2024 13:34 #293621
Replied by andypugh on topic Calibration of screw variation along axis
Screw-mapping is done with a compensation file:
Look for "COMP_FILE" here.
linuxcnc.org/docs/stable/html/config/ini...ub:ini:sec:joint-num
You can either tabulate nominal position v actual position, or nominal position v error to nominal.
The following user(s) said Thank You: smc.collins, Unlogic
