External Offset pins do not appear in Halconfig?
01 Mar 2024 21:36 #294863
by MFairleaf
External Offset pins do not appear in Halconfig? was created by MFairleaf
Hello, I’ve written a custom external offsets component but can’t find the pins to connect to. According to the External Offsets document there ought to be axis.2.eoffset.[lots of variations] but I can’t find any pins matching “eoffset” anywhere.
- Thank you received: 5934
01 Mar 2024 21:39 #294864
Replied by tommylight on topic External Offset pins do not appear in Halconfig?
-is the component compiled and installed?
-is the component loaded with loadrt in hal?
-can you see the component loaded using "show hal configuration" from the "machine" menu?
01 Mar 2024 21:42 #294865
Replied by andypugh on topic External Offset pins do not appear in Halconfig?
Which version of LinuxCNC are you running?
I think that external offsets were introduced in LinuxCNC 2.8. If you are using an older version of that you won't see them.
The following user(s) said Thank You: MFairleaf
11 Mar 2024 22:34 #295696
by MFairleaf
Replied by MFairleaf on topic External Offset pins do not appear in Halconfig?
Upgrading solved this problem. Thank you.
Time to create page: 0.117 seconds
