How to achieve tilt-plane processing instead of RTCP
04 Mar 2024 13:51 #295135
by sunrui
How to achieve tilt-plane processing instead of RTCP was created by sunrui
Is there a G68.2 instruction similar to the FANUC?
04 Mar 2024 18:18 #295155
Replied by Aciera on topic How to achieve tilt-plane processing instead of RTCP
G68.2 (Tilted Work Plane) is not implemented by default but I have made a python remap implementation.
Have a look in this simulation configuration here:
forum.linuxcnc.org/show-your-stuff/49103...-head?start=0#271334
The TWP implementation requires the 'remap.py' the 'twp_helper.comp' and the custom kinematic component.
Have a look at the Documentation in the zipped up config folder.
The following user(s) said Thank You: tommylight, sunrui
05 Mar 2024 12:25 #295223
by sunrui
Replied by sunrui on topic How to achieve tilt-plane processing instead of RTCP
Thank you very much for answering the questions that have plagued me for a long time.
Time to create page: 0.087 seconds
