Z-axis stuttering only on low speeds
- rm446
24 Jun 2016 01:40 #76529
by rm446
Z-axis stuttering only on low speeds was created by rm446
I have an old Dyna Myte 2400 that I've reconfigured/hacked to work with a Gecko g540 driver. The Steppers and power supply are the originals that came with the Dyna. I've thought I had this thing working well for a while now but I'm getting a strange error.
When I try to jog the z-axis at a slow speed, the motor simply stutters. However this never happens if I use a high jog speed, only speeds under 2-3 IPM cause problems. There's even an intermediate range of speed where sometimes it stutters and sometimes it moves.
Most thread's I've seen talk about motors messing up at high speeds but not so much at low speeds. Is there some setting in the stepper config wizard I can toy with to address this issue?
Thanks!
Thanks!
- Rick G
- Thank you received: 114
24 Jun 2016 20:29 #76600
by Rick G
Replied by Rick G on topic Z-axis stuttering only on low speeds
You might want to try reducing your acceleration.
Also check your step and direction timing.
Rick G
Rick G
- Thank you received: 5231
24 Jun 2016 21:42 #76606
Replied by PCW on topic Z-axis stuttering only on low speeds
I would echo the timing check
I've seen a couple instances of stuttering at low speeds on G540s with marginal step/dir timings
I would at least double the minimum timing specs, in fact for a parallel port driven G540,
there's no big cost with using 5 usec for all timings
- Thank you received: 7339
26 Jun 2016 00:44 #76665
Replied by tommylight on topic Z-axis stuttering only on low speeds
Also G540 does not like high inductance motors at all.
On the other hand, if you have a big low inductance motor on Z, check you power supply, it might not have enough power, or lower the amps on the Z axis and check if that happens again.
I concur with the other 2 replies to check timings as first order of business.
Regards
Regards
Moderators: piasdom
Time to create page: 0.199 seconds
