VFD & Motor - Belt Ratio
- ImJay
28 Sep 2016 10:14 - 28 Sep 2016 10:15 #81033
by ImJay
VFD & Motor - Belt Ratio was created by ImJay
Generally what do people run for their ratios for a vfd & motor to the spindle?
I've seen quite a bit of 1:1 & 6:1 for low torque, but finding a decent priced motor to push over 3krpm is becoming quite the issue.
I'd be looking at putting an encoder on the spindle to potentially rigid tap.
40rpm-3/4krpm is my end goal without pushing the frequency of the vfd too far (or too low). Approx 3-5hp motor, 7-10hp rated vfd.
Any one have positive results with a 'larger' setup?
Last edit: 28 Sep 2016 10:15 by ImJay.
- Thank you received: 4636
28 Sep 2016 23:48 #81064
Replied by andypugh on topic VFD & Motor - Belt Ratio
One of my lathes has a 4-pole motor (1500rpm) which I push to 120Hz (for 3600rpm motor speed) and that works fairly well.
I get the extra torque of the 4-pole at 50Hz but the extra speed when needed. Final spindle speed max is 1500 rpm.
My other lathe has a mechanical gearbox with magnetic clutches to help span the range, but that goes to 3000 rpm spindle speed.
Moderators: piasdom
