Retrofitting a 1986 Maho MH400E
- ThisOldTony
- Thank you received: 3
Wondering if you could share part # and other information about repairing the tubing and fittings?
Think young
BOB
- Thank you received: 5983
Thank you.
[edit]
Thinking about it, I hot unplugged the pendant, which means I hot unplugged an encoder. Sergei pointed out that the error is caused by the hm2.pci driver not accepting the parameters it is being passed from line 12 of my HAL, whic is probably:
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=300xxx"
Any trouble shooting assistance appreciated.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/maho/linuxcnc/configs/MAHO_MH400E'
Machine configuration file is 'MAHO_MH400E.ini'
INIFILE=/home/maho/linuxcnc/configs/MAHO_MH400E/MAHO_MH400E.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Found file(REL): ./MAHO_MH400E.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3161
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
./MAHO_MH400E.hal:12: exit value: 1
./MAHO_MH400E.hal:12: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
3161
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000008f000 (usable)
[ 0.000000] BIOS-e820: 000000000008f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007f535000 (usable)
[ 0.000000] BIOS-e820: 000000007f535000 - 000000007f53d000 (reserved)
[ 0.000000] BIOS-e820: 000000007f53d000 - 000000007f5cd000 (usable)
[ 0.000000] BIOS-e820: 000000007f5cd000 - 000000007f5d1000 (reserved)
[ 0.000000] BIOS-e820: 000000007f5d1000 - 000000007f660000 (usable)
[ 0.000000] BIOS-e820: 000000007f660000 - 000000007f6f0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f6f0000 - 000000007f6f4000 (usable)
[ 0.000000] BIOS-e820: 000000007f6f4000 - 000000007f6ff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007f6ff000 - 000000007f700000 (usable)
[ 0.000000] BIOS-e820: 000000007f700000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0000000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: /D945GCLF2D, BIOS LF94510J.86A.0122.2008.1117.0113 11/17/2008
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7f700 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-E0FFF write-protect
[ 0.000000] E1000-E7FFF uncachable
[ 0.000000] E8000-E8FFF write-protect
[ 0.000000] E9000-EFFFF uncachable
[ 0.000000] F0000-F0FFF write-protect
[ 0.000000] F1000-F7FFF uncachable
[ 0.000000] F8000-F8FFF write-protect
[ 0.000000] F9000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 080000000 write-back
[ 0.000000] 1 base 07F800000 mask 0FF800000 uncachable
[ 0.000000] 2 base 07F700000 mask 0FFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe200] fe200
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c008b000] 8b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36530000 - 37290000
[ 0.000000] ACPI: RSDP 000fe020 00014 (v00 INTEL )
[ 0.000000] ACPI: RSDT 7f6fd038 00034 (v01 INTEL D945GLF2 0000007A 01000013)
[ 0.000000] ACPI: FACP 7f6fc000 00074 (v01 INTEL D945GLF2 0000007A MSFT 01000013)
[ 0.000000] ACPI: DSDT 7f6f7000 045EC (v01 INTEL D945GLF2 0000007A MSFT 01000013)
[ 0.000000] ACPI: FACS 7f6a3000 00040
[ 0.000000] ACPI: APIC 7f6f6000 00078 (v01 INTEL D945GLF2 0000007A MSFT 01000013)
[ 0.000000] ACPI: WDDT 7f6f5000 00040 (v01 INTEL D945GLF2 0000007A MSFT 01000013)
[ 0.000000] ACPI: MCFG 7f6f4000 0003C (v01 INTEL D945GLF2 0000007A MSFT 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1151MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007f700
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000008f
[ 0.000000] 0: 0x00000100 -> 0x0007f535
[ 0.000000] 0: 0x0007f53d -> 0x0007f5cd
[ 0.000000] 0: 0x0007f5d1 -> 0x0007f660
[ 0.000000] 0: 0x0007f6f0 -> 0x0007f6f4
[ 0.000000] 0: 0x0007f6ff -> 0x0007f700
[ 0.000000] On node 0 totalpages: 521688
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5540200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3935 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2303 pages used for memmap
[ 0.000000] HighMem zone: 292188 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000008f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:70000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517609
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=49f9f0cc-6d29-4832-9f52-64da6f29c158 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4175744 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007f700)
[ 0.000000] Memory: 2045672k/2087936k available (3495k kernel code, 41080k reserved, 1237k data, 416k init, 1177964k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration failed
[ 0.000000] TSC: PIT calibration matches PMTIMER. 1 loops
[ 0.000000] Detected 1596.001 MHz processor.
[ 0.012005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3192.00 BogoMIPS (lpj=6384004)
[ 0.012017] pid_max: default: 32768 minimum: 301
[ 0.012151] Security Framework initialized
[ 0.012161] AppArmor: AppArmor disabled by boot time parameter
[ 0.012212] Mount-cache hash table entries: 512
[ 0.012663] Initializing cgroup subsys cpuacct
[ 0.012671] Initializing cgroup subsys memory
[ 0.012694] Initializing cgroup subsys devices
[ 0.012701] Initializing cgroup subsys freezer
[ 0.012706] Initializing cgroup subsys net_cls
[ 0.012712] Initializing cgroup subsys blkio
[ 0.012729] Initializing cgroup subsys perf_event
[ 0.012790] Disabled fast string operations
[ 0.012798] CPU: Physical Processor ID: 0
[ 0.012803] CPU: Processor Core ID: 0
[ 0.012811] mce: CPU supports 5 MCE banks
[ 0.012825] CPU0: Thermal monitoring enabled (TM1)
[ 0.012912] ACPI: Core revision 20120320
[ 0.023003] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.023425] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.063125] CPU0: Intel(R) Atom(TM) CPU 330 @ 1.60GHz stepping 02
[ 0.064003] Performance Events: PEBS fmt0+, LBR disabled due to erratumAtom events, Intel PMU driver.
[ 0.064003] ... version: 3
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 2
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 000000007fffffff
[ 0.064003] ... fixed-purpose events: 3
[ 0.064003] ... event mask: 0000000700000003
[ 0.072384] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.084064] CPU 1 irqstacks, hard=f50d4000 soft=f50d6000
[ 0.084071] Booting Node 0, Processors #1
[ 0.016000] Initializing CPU#1
[ 0.016000] Disabled fast string operations
[ 0.096076] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.096165] Brought up 2 CPUs
[ 0.096174] Total of 2 processors activated (6384.00 BogoMIPS).
[ 0.097046] devtmpfs: initialized
[ 0.097046] PM: Registering ACPI NVS region [mem 0x7f660000-0x7f6effff] (589824 bytes)
[ 0.097046] dummy:
[ 0.097046] NET: Registered protocol family 16
[ 0.100139] ACPI: bus type pci registered
[ 0.100326] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.100337] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.100343] PCI: Using MMCONFIG for extended config space
[ 0.100350] PCI: Using configuration type 1 for base access
[ 0.101981] bio: create slab <bio-0> at 0
[ 0.101981] ACPI: Added _OSI(Module Device)
[ 0.101981] ACPI: Added _OSI(Processor Device)
[ 0.101981] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.101981] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.105331] ACPI: EC: Look up EC in DSDT
[ 0.111606] ACPI: Interpreter enabled
[ 0.111625] ACPI: (supports S0 S1 S4 S5)
[ 0.111694] ACPI: Using IOAPIC for interrupt routing
[ 0.123566] ACPI: No dock devices found.
[ 0.123584] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.126238] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.131330] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.131340] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.131349] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.131357] pci_root PNP0A03:00: host bridge window [mem 0x000e0000-0x000effff]
[ 0.131365] pci_root PNP0A03:00: host bridge window [mem 0xf8000000-0xfebfffff]
[ 0.131373] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xf0000000]
[ 0.131480] PCI host bridge to bus 0000:00
[ 0.131490] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.131498] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.131506] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.131514] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff]
[ 0.131522] pci_bus 0000:00: root bus resource [mem 0xf8000000-0xfebfffff]
[ 0.131530] pci_bus 0000:00: root bus resource [mem 0x80000000-0xf0000000]
[ 0.131556] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.131644] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[ 0.131669] pci 0000:00:02.0: reg 10: [mem 0x90300000-0x9037ffff]
[ 0.131684] pci 0000:00:02.0: reg 14: [io 0x20e0-0x20e7]
[ 0.131699] pci 0000:00:02.0: reg 18: [mem 0x80000000-0x8fffffff pref]
[ 0.131713] pci 0000:00:02.0: reg 1c: [mem 0x90380000-0x903bffff]
[ 0.131823] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.131913] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.131965] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400
[ 0.132073] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.132119] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.132208] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.132257] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.132321] pci 0000:00:1d.0: reg 20: [io 0x2080-0x209f]
[ 0.132374] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.132438] pci 0000:00:1d.1: reg 20: [io 0x2060-0x207f]
[ 0.132493] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.132556] pci 0000:00:1d.2: reg 20: [io 0x2040-0x205f]
[ 0.132610] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.132673] pci 0000:00:1d.3: reg 20: [io 0x2020-0x203f]
[ 0.132741] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.132773] pci 0000:00:1d.7: reg 10: [mem 0x903c0000-0x903c03ff]
[ 0.132877] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.132914] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.133010] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.133141] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.133170] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask 007f)
[ 0.133226] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.133250] pci 0000:00:1f.1: reg 10: [io 0x20d8-0x20df]
[ 0.133268] pci 0000:00:1f.1: reg 14: [io 0x20f4-0x20f7]
[ 0.133285] pci 0000:00:1f.1: reg 18: [io 0x20d0-0x20d7]
[ 0.133303] pci 0000:00:1f.1: reg 1c: [io 0x20f0-0x20f3]
[ 0.133320] pci 0000:00:1f.1: reg 20: [io 0x20b0-0x20bf]
[ 0.133383] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.133409] pci 0000:00:1f.2: reg 10: [io 0x20c8-0x20cf]
[ 0.133426] pci 0000:00:1f.2: reg 14: [io 0x20ec-0x20ef]
[ 0.133442] pci 0000:00:1f.2: reg 18: [io 0x20c0-0x20c7]
[ 0.133459] pci 0000:00:1f.2: reg 1c: [io 0x20e8-0x20eb]
[ 0.133475] pci 0000:00:1f.2: reg 20: [io 0x20a0-0x20af]
[ 0.133524] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.133554] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.133628] pci 0000:00:1f.3: reg 20: [io 0x2000-0x201f]
[ 0.133769] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 0.133797] pci 0000:01:00.0: reg 10: [io 0x1000-0x10ff]
[ 0.133840] pci 0000:01:00.0: reg 18: [mem 0x90200000-0x90200fff 64bit]
[ 0.133869] pci 0000:01:00.0: reg 20: [mem 0x90000000-0x9000ffff 64bit pref]
[ 0.133891] pci 0000:01:00.0: reg 30: [mem 0xfffe0000-0xffffffff pref]
[ 0.133949] pci 0000:01:00.0: supports D1 D2
[ 0.133956] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.140044] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.140056] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.140066] pci 0000:00:1c.0: bridge window [mem 0x90200000-0x902fffff]
[ 0.140079] pci 0000:00:1c.0: bridge window [mem 0x90000000-0x900fffff 64bit pref]
[ 0.140148] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.140228] pci 0000:00:1c.3: PCI bridge to [bus 03-03]
[ 0.140290] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.140316] pci 0000:04:00.0: reg 10: [mem 0x90100000-0x9010ffff]
[ 0.140456] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.140469] pci 0000:00:1e.0: bridge window [mem 0x90100000-0x901fffff]
[ 0.140482] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.140491] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.140499] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.140508] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff] (subtractive decode)
[ 0.140516] pci 0000:00:1e.0: bridge window [mem 0xf8000000-0xfebfffff] (subtractive decode)
[ 0.140525] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xf0000000] (subtractive decode)
[ 0.140557] pci_bus 0000:00: on NUMA node 0
[ 0.140569] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.141134] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
[ 0.141757] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.141944] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 0.142120] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 0.142417] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.156319] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.156533] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.156745] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.156951] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.157158] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.157369] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.157578] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.157788] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.157983] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.157983] vgaarb: loaded
[ 0.157983] vgaarb: bridge control possible 0000:00:02.0
[ 0.157983] PCI: Using ACPI for IRQ routing
[ 0.162166] PCI: pci_cache_line_size set to 64 bytes
[ 0.162298] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.162306] reserve RAM buffer: 000000000008f000 - 000000000008ffff
[ 0.162314] reserve RAM buffer: 000000007f535000 - 000000007fffffff
[ 0.162322] reserve RAM buffer: 000000007f5cd000 - 000000007fffffff
[ 0.162330] reserve RAM buffer: 000000007f660000 - 000000007fffffff
[ 0.162338] reserve RAM buffer: 000000007f6f4000 - 000000007fffffff
[ 0.162345] reserve RAM buffer: 000000007f700000 - 000000007fffffff
[ 0.162860] hpet clockevent registered
[ 0.162872] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.162889] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.164049] Switching to clocksource hpet
[ 0.164244] pnp: PnP ACPI init
[ 0.164279] ACPI: bus type pnp registered
[ 0.166875] pnp 00:00: [bus 00-ff]
[ 0.166885] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.166893] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.166901] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.166909] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.166916] pnp 00:00: [mem 0x000e0000-0x000effff window]
[ 0.166924] pnp 00:00: [mem 0xf8000000-0xfebfffff window]
[ 0.166932] pnp 00:00: [mem 0x80000000-0xf0000000 window]
[ 0.167054] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.167095] pnp 00:01: [mem 0xf0000000-0xf3ffffff]
[ 0.167095] pnp 00:01: [mem 0xfed13000-0xfed13fff]
[ 0.167095] pnp 00:01: [mem 0xfed14000-0xfed17fff]
[ 0.167095] pnp 00:01: [mem 0xfed18000-0xfed18fff]
[ 0.167095] pnp 00:01: [mem 0xfed19000-0xfed19fff]
[ 0.167095] pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
[ 0.167102] pnp 00:01: [mem 0xfed20000-0xfed3ffff]
[ 0.167109] pnp 00:01: [mem 0xfed45000-0xfed99fff]
[ 0.167116] pnp 00:01: [mem 0x000c0000-0x000dffff]
[ 0.167123] pnp 00:01: [mem 0x000e0000-0x000fffff]
[ 0.167251] system 00:01: [mem 0xf0000000-0xf3ffffff] could not be reserved
[ 0.167261] system 00:01: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.167270] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.167279] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.167289] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.167298] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.167307] system 00:01: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.167316] system 00:01: [mem 0xfed45000-0xfed99fff] has been reserved
[ 0.167325] system 00:01: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.167335] system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.167345] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.167786] pnp 00:02: [io 0x0000-0x000f]
[ 0.167795] pnp 00:02: [io 0x0081-0x0083]
[ 0.167801] pnp 00:02: [io 0x0087]
[ 0.167808] pnp 00:02: [io 0x0089-0x008b]
[ 0.167814] pnp 00:02: [io 0x008f]
[ 0.167821] pnp 00:02: [io 0x00c0-0x00df]
[ 0.167829] pnp 00:02: [dma 4]
[ 0.167909] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.167945] pnp 00:03: [io 0x0070-0x0071]
[ 0.167953] pnp 00:03: [io 0x0074-0x0077]
[ 0.167976] pnp 00:03: [irq 8]
[ 0.168079] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.168123] pnp 00:04: [io 0x00f0]
[ 0.168138] pnp 00:04: [irq 13]
[ 0.168227] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.168272] pnp 00:05: [io 0x0061]
[ 0.168355] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.168394] pnp 00:06: [io 0x0500-0x053f]
[ 0.168401] pnp 00:06: [io 0x0400-0x047f]
[ 0.168408] pnp 00:06: [io 0x0092]
[ 0.168415] pnp 00:06: [io 0x0680-0x06ff]
[ 0.168421] pnp 00:06: [io 0x0010-0x001f]
[ 0.168428] pnp 00:06: [io 0x0072-0x0073]
[ 0.168434] pnp 00:06: [io 0x0080]
[ 0.168445] pnp 00:06: [io 0x0084-0x0086]
[ 0.168452] pnp 00:06: [io 0x0088]
[ 0.168458] pnp 00:06: [io 0x008c-0x008e]
[ 0.168465] pnp 00:06: [io 0x0090-0x009f]
[ 0.168600] system 00:06: [io 0x0500-0x053f] has been reserved
[ 0.168609] system 00:06: [io 0x0400-0x047f] has been reserved
[ 0.168618] system 00:06: [io 0x0680-0x06ff] has been reserved
[ 0.168629] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.168772] pnp 00:07: [io 0x0060]
[ 0.168780] pnp 00:07: [io 0x0064]
[ 0.168907] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.169731] pnp 00:08: [mem 0xfec00000-0xfec000ff]
[ 0.169827] pnp 00:08: Plug and Play ACPI device, IDs PNP0003 (active)
[ 0.170006] pnp: PnP ACPI: found 9 devices
[ 0.170013] ACPI: ACPI bus type pnp unregistered
[ 0.170022] PnPBIOS: Disabled by ACPI PNP
[ 0.212845] pci 0000:01:00.0: no compatible bridge window for [mem 0xfffe0000-0xffffffff pref]
[ 0.212885] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 0.212897] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 0.212907] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 02-02] add_size 200000
[ 0.212926] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 0.212936] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.212946] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000
[ 0.212979] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.212989] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.212998] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.213007] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.213016] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.213025] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.213039] pci 0000:00:1c.2: BAR 14: assigned [mem 0x90400000-0x905fffff]
[ 0.213051] pci 0000:00:1c.2: BAR 15: assigned [mem 0x90600000-0x907fffff 64bit pref]
[ 0.213061] pci 0000:00:1c.3: BAR 14: assigned [mem 0x90800000-0x909fffff]
[ 0.213072] pci 0000:00:1c.3: BAR 15: assigned [mem 0x90a00000-0x90bfffff 64bit pref]
[ 0.213085] pci 0000:00:1c.2: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.213094] pci 0000:00:1c.3: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.213109] pci 0000:01:00.0: BAR 6: assigned [mem 0x90020000-0x9003ffff pref]
[ 0.213119] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.213128] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.213139] pci 0000:00:1c.0: bridge window [mem 0x90200000-0x902fffff]
[ 0.213150] pci 0000:00:1c.0: bridge window [mem 0x90000000-0x900fffff 64bit pref]
[ 0.213164] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.213172] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.213184] pci 0000:00:1c.2: bridge window [mem 0x90400000-0x905fffff]
[ 0.213194] pci 0000:00:1c.2: bridge window [mem 0x90600000-0x907fffff 64bit pref]
[ 0.213207] pci 0000:00:1c.3: PCI bridge to [bus 03-03]
[ 0.213216] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.213227] pci 0000:00:1c.3: bridge window [mem 0x90800000-0x909fffff]
[ 0.213238] pci 0000:00:1c.3: bridge window [mem 0x90a00000-0x90bfffff 64bit pref]
[ 0.213251] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 0.213263] pci 0000:00:1e.0: bridge window [mem 0x90100000-0x901fffff]
[ 0.213365] pci 0000:00:1e.0: setting latency timer to 64
[ 0.213376] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.213384] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.213392] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.213399] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000effff]
[ 0.213407] pci_bus 0000:00: resource 8 [mem 0xf8000000-0xfebfffff]
[ 0.213415] pci_bus 0000:00: resource 9 [mem 0x80000000-0xf0000000]
[ 0.213422] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 0.213430] pci_bus 0000:01: resource 1 [mem 0x90200000-0x902fffff]
[ 0.213438] pci_bus 0000:01: resource 2 [mem 0x90000000-0x900fffff 64bit pref]
[ 0.213446] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.213453] pci_bus 0000:02: resource 1 [mem 0x90400000-0x905fffff]
[ 0.213461] pci_bus 0000:02: resource 2 [mem 0x90600000-0x907fffff 64bit pref]
[ 0.213469] pci_bus 0000:03: resource 0 [io 0x4000-0x4fff]
[ 0.213477] pci_bus 0000:03: resource 1 [mem 0x90800000-0x909fffff]
[ 0.213485] pci_bus 0000:03: resource 2 [mem 0x90a00000-0x90bfffff 64bit pref]
[ 0.213493] pci_bus 0000:04: resource 1 [mem 0x90100000-0x901fffff]
[ 0.213500] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 0.213508] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 0.213515] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.213523] pci_bus 0000:04: resource 7 [mem 0x000e0000-0x000effff]
[ 0.213531] pci_bus 0000:04: resource 8 [mem 0xf8000000-0xfebfffff]
[ 0.213538] pci_bus 0000:04: resource 9 [mem 0x80000000-0xf0000000]
[ 0.213764] NET: Registered protocol family 2
[ 0.213937] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.214482] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.215461] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.215935] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.215944] TCP: reno registered
[ 0.215955] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.215978] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.216347] NET: Registered protocol family 1
[ 0.216392] pci 0000:00:02.0: Boot video device
[ 0.216775] PCI: CLS 64 bytes, default 64
[ 0.216920] Unpacking initramfs...
[ 0.872480] Freeing initrd memory: 13696k freed
[ 0.887898] audit: initializing netlink socket (disabled)
[ 0.887946] type=2000 audit(1610810261.884:1): initialized
[ 0.914241] highmem bounce pool size: 64 pages
[ 0.914256] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.914847] VFS: Disk quotas dquot_6.5.2
[ 0.914926] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.915125] msgmni has been set to 1721
[ 0.915622] alg: No test for stdrng (krng)
[ 0.915724] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.915736] io scheduler noop registered
[ 0.915742] io scheduler deadline registered
[ 0.915802] io scheduler cfq registered (default)
[ 0.916398] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.916459] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.916466] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.917381] GHES: HEST is not enabled!
[ 0.917414] isapnp: Scanning for PnP cards...
[ 1.270924] isapnp: No Plug & Play device found
[ 1.271084] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.272183] Linux agpgart interface v0.103
[ 1.272418] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[ 1.272749] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.273013] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.273287] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x80000000
[ 1.273652] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.276908] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.276996] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.277333] mousedev: PS/2 mouse device common for all mice
[ 1.277448] rtc_cmos 00:03: RTC can wake from S4
[ 1.277702] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.277743] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.278042] TCP: cubic registered
[ 1.278215] NET: Registered protocol family 10
[ 1.278760] Mobile IPv6
[ 1.278769] NET: Registered protocol family 17
[ 1.278789] Registering the dns_resolver key type
[ 1.278902] Using IPI No-Shortcut mode
[ 1.279264] PM: Hibernation image not present or could not be loaded.
[ 1.279304] registered taskstats version 1
[ 1.280095] rtc_cmos 00:03: setting system clock to 2021-01-16 15:17:42 UTC (1610810262)
[ 1.280458] Freeing unused kernel memory: 416k freed
[ 1.280914] Write protecting the kernel text: 3496k
[ 1.280977] Write protecting the kernel read-only data: 984k
[ 1.314323] udevd[49]: starting version 175
[ 1.361938] usbcore: registered new interface driver usbfs
[ 1.362010] usbcore: registered new interface driver hub
[ 1.371981] usbcore: registered new device driver usb
[ 1.373214] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.373368] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.373381] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.373458] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.373510] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.373532] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.389540] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.395076] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.395148] ehci_hcd 0000:00:1d.7: irq 23, io mem 0x903c0000
[ 1.405363] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.405485] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.405496] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.405504] usb usb1: Product: EHCI Host Controller
[ 1.405511] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.405522] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.406057] hub 1-0:1.0: USB hub found
[ 1.406080] hub 1-0:1.0: 8 ports detected
[ 1.406398] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.406410] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.406439] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.406486] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.406590] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.406599] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.406606] usb usb2: Product: UHCI Host Controller
[ 1.406613] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.406623] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.406949] hub 2-0:1.0: USB hub found
[ 1.406966] hub 2-0:1.0: 2 ports detected
[ 1.407216] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.407226] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.407255] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.407331] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.407434] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.407445] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.407454] usb usb3: Product: UHCI Host Controller
[ 1.407461] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.407469] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.410777] hub 3-0:1.0: USB hub found
[ 1.410797] hub 3-0:1.0: 2 ports detected
[ 1.411053] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.411067] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.411098] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.411183] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.411293] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.411304] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.411312] usb usb4: Product: UHCI Host Controller
[ 1.411321] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.411328] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.411956] hub 4-0:1.0: USB hub found
[ 1.411975] hub 4-0:1.0: 2 ports detected
[ 1.412270] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.412282] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.412308] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.412390] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.412502] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.412513] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.412522] usb usb5: Product: UHCI Host Controller
[ 1.412530] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.412537] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.413818] hub 5-0:1.0: USB hub found
[ 1.413837] hub 5-0:1.0: 2 ports detected
[ 1.444253] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.444822] r8169 0000:01:00.0: eth0: RTL8168c/8111c at 0xf8012000, 00:1c:c0:c0:e3:0e, XID 1c4000c0 IRQ 16
[ 1.444834] r8169 0000:01:00.0: eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 1.447384] SCSI subsystem initialized
[ 1.472340] libata version 3.00 loaded.
[ 1.473305] ata_piix 0000:00:1f.1: version 2.13
[ 1.473433] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.474393] scsi0 : ata_piix
[ 1.474681] scsi1 : ata_piix
[ 1.475742] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x20b0 irq 14
[ 1.475752] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x20b8 irq 15
[ 1.475913] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.476204] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.477091] scsi2 : ata_piix
[ 1.477296] scsi3 : ata_piix
[ 1.477920] ata3: SATA max UDMA/133 cmd 0x20c8 ctl 0x20ec bmdma 0x20a0 irq 19
[ 1.477931] ata4: SATA max UDMA/133 cmd 0x20c0 ctl 0x20e8 bmdma 0x20a8 irq 19
[ 1.478086] ata2: port disabled--ignoring
[ 1.483048] microcode: CPU0 sig=0x106c2, pf=0x8, revision=0x210
[ 1.569843] microcode: CPU0 updated to revision 0x219, date = 2009-04-10
[ 1.572158] microcode: CPU1 sig=0x106c2, pf=0x8, revision=0x210
[ 1.582959] microcode: CPU1 updated to revision 0x219, date = 2009-04-10
[ 1.584719] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.648177] ata3.00: ATA-0: CF CARD 8GB, Ver2.20K, max UDMA/100
[ 1.648189] ata3.00: 15761088 sectors, multi 0: LBA
[ 1.648198] ata3.00: applying bridge limits
[ 1.656180] ata3.00: configured for UDMA/100
[ 1.656475] scsi 2:0:0:0: Direct-Access ATA CF CARD 8GB Ver2 PQ: 0 ANSI: 5
[ 1.672774] sd 2:0:0:0: [sda] 15761088 512-byte logical blocks: (8.06 GB/7.51 GiB)
[ 1.673009] sd 2:0:0:0: [sda] Write Protect is off
[ 1.673019] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.673121] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1.675664] sda: sda1
[ 1.676554] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.681637] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.716066] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.848737] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 1.848749] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.848759] usb 1-1: Product: USB 2.0 Hub
[ 1.849208] hub 1-1:1.0: USB hub found
[ 1.849350] hub 1-1:1.0: 4 ports detected
[ 1.884061] Refined TSC clocksource calibration: 1596.003 MHz.
[ 1.884080] Switching to clocksource tsc
[ 2.136235] usb 1-1.1: new low-speed USB device number 3 using ehci_hcd
[ 2.263476] usb 1-1.1: New USB device found, idVendor=04d9, idProduct=1603
[ 2.263486] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.263494] usb 1-1.1: Product: USB Keyboard
[ 2.263500] usb 1-1.1: Manufacturer:
[ 2.283580] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
[ 2.283908] generic-usb 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.7-1.1/input0
[ 2.306265] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.1/1-1.1:1.1/input/input1
[ 2.306860] generic-usb 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.7-1.1/input1
[ 2.307488] usbcore: registered new interface driver usbhid
[ 2.307498] usbhid: USB HID core driver
[ 2.336242] usb 1-1.3: new high-speed USB device number 4 using ehci_hcd
[ 2.446602] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=1436
[ 2.446612] usb 1-1.3: New USB device strings: Mfr=4, Product=3, SerialNumber=0
[ 2.446621] usb 1-1.3: Product: HUAWEI Mobile
[ 2.446627] usb 1-1.3: Manufacturer: HUAWEI Technology
[ 2.467832] Initializing USB Mass Storage driver...
[ 2.474742] scsi9 : usb-storage 1-1.3:1.5
[ 2.475473] scsi10 : usb-storage 1-1.3:1.6
[ 2.476451] usbcore: registered new interface driver usb-storage
[ 2.476461] USB Mass Storage support registered.
[ 2.536243] usb 1-1.4: new full-speed USB device number 5 using ehci_hcd
[ 2.647729] usb 1-1.4: New USB device found, idVendor=04e7, idProduct=0050
[ 2.647739] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.647747] usb 1-1.4: Product: Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface
[ 2.647754] usb 1-1.4: Manufacturer: EloTouchSystems,Inc
[ 2.647760] usb 1-1.4: SerialNumber: 50U18368
[ 2.652515] input: EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
[ 2.652774] generic-usb 0003:04E7:0050.0003: input,hidraw2: USB HID v1.00 Pointer [EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface] on usb-0000:00:1d.7-1.4/input0
[ 3.473682] scsi 9:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 3.473910] scsi 10:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
[ 3.476427] scsi 9:0:0:0: Attached scsi generic sg1 type 5
[ 3.477195] sd 10:0:0:0: Attached scsi generic sg2 type 0
[ 3.479016] sd 10:0:0:0: [sdb] Attached SCSI removable disk
[ 3.496400] sr0: scsi-1 drive
[ 3.496414] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.497764] sr 9:0:0:0: Attached scsi CD-ROM sr0
[ 6.938521] kjournald starting. Commit interval 5 seconds
[ 6.938574] EXT3-fs (sda1): mounted filesystem with ordered data mode
[ 7.947857] udevd[351]: starting version 175
[ 8.276402] [drm] Initialized drm 1.1.0 20060810
[ 8.287275] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 8.287298] ACPI: Sleep Button [SLPB]
[ 8.287492] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.287506] ACPI: Power Button [PWRF]
[ 8.373673] i915 0000:00:02.0: setting latency timer to 64
[ 8.416340] intel_rng: Firmware space is locked read-only. If you can't or
[ 8.416345] intel_rng: don't want to disable this in firmware setup, and if
[ 8.416349] intel_rng: you are certain that your system has a functional
[ 8.416352] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 8.436480] iTCO_vendor_support: vendor-support=0
[ 8.439968] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 8.440256] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[ 8.440403] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 8.505844] leds_ss4200: no LED devices found
[ 8.558302] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 8.558311] [drm] Driver supports precise vblank timestamp query.
[ 8.558876] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 8.583287] [drm] initialized overlay support
[ 8.607289] fbcon: inteldrmfb (fb0) is primary device
[ 8.667021] Console: switching to colour frame buffer device 128x48
[ 8.676487] cdc_ether 1-1.3:1.1: wwan0: register 'cdc_ether' at usb-0000:00:1d.7-1.3, Mobile Broadband Network Device, 02:50:f3:00:00:00
[ 8.676577] usbcore: registered new interface driver cdc_ether
[ 8.683424] usbcore: registered new interface driver usbserial
[ 8.683477] usbcore: registered new interface driver usbserial_generic
[ 8.683515] USB Serial support registered for generic
[ 8.683593] usbserial: USB Serial Driver core
[ 8.695374] usbcore: registered new interface driver option
[ 8.695431] USB Serial support registered for GSM modem (1-port)
[ 8.695665] option 1-1.3:1.0: GSM modem (1-port) converter detected
[ 8.695948] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 8.697543] option 1-1.3:1.3: GSM modem (1-port) converter detected
[ 8.697825] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 8.697870] option 1-1.3:1.4: GSM modem (1-port) converter detected
[ 8.698060] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 8.702902] fb0: inteldrmfb frame buffer device
[ 8.702911] drm: registered panic notifier
[ 8.702935] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 8.703019] ACPI Warning: 0x00002000-0x0000201f SystemIO conflicts with Region \_SB_.PCI0.LPC_.SMB1 1 (20120320/utaddress-251)
[ 8.703043] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.209000] EXT3-fs (sda1): using internal journal
[ 10.289968] loop: module loaded
[ 12.432146] RPC: Registered named UNIX socket transport module.
[ 12.432157] RPC: Registered udp transport module.
[ 12.432165] RPC: Registered tcp transport module.
[ 12.432172] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 12.459038] FS-Cache: Loaded
[ 12.498443] NFS: Registering the id_resolver key type
[ 12.498506] FS-Cache: Netfs 'nfs' registered for caching
[ 12.524470] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 14.794763] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 14.834667] Bluetooth: Core ver 2.16
[ 14.834734] NET: Registered protocol family 31
[ 14.834742] Bluetooth: HCI device and connection manager initialized
[ 14.834750] Bluetooth: HCI socket layer initialized
[ 14.834759] Bluetooth: L2CAP socket layer initialized
[ 14.834780] Bluetooth: SCO socket layer initialized
[ 14.897252] lp: driver loaded but no devices found
[ 14.912365] ppdev: user-space parallel port driver
[ 14.921947] Bluetooth: RFCOMM TTY layer initialized
[ 14.921967] Bluetooth: RFCOMM socket layer initialized
[ 14.921977] Bluetooth: RFCOMM ver 1.11
[ 14.987434] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.987445] Bluetooth: BNEP filters: protocol multicast
[ 18.528409] r8169 0000:01:00.0: eth0: link down
[ 18.528860] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.039238] I-pipe: head domain RTAI registered.
[ 26.039256] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 26.039381] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 26.039392] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596001000, CPU_FREQ 1596001000
[ 26.039402] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 26.039411] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8235750
[ 26.427759] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 26.449447] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 26.449465] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 26.449476] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596001000 hz.
[ 26.449483] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 27.984531] RTAI[math]: loaded.
[ 29.294682] hm2: loading Mesa HostMot2 driver version 0.15
[ 29.448856] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 29.448968] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 29.451574] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 29.456197] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 29.463639] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 29.478048] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 29.497426] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 29.511027] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 29.580676] hm2/hm2_5i25.0: hm2_sserial_waitfor: Timeout (24mS) waiting for addr 5d00 &mask ff00 val 0
[ 29.580693] hm2/hm2_5i25.0: DATA addr 5e00 after timeout: 0
[ 29.580703] hm2/hm2_5i25.0: Timeout trying to read config data in sserial_get_bytes
[ 29.580715] hm2/hm2_5i25.0: Failed to read/setup the globals on hm2_5i25.0.7i77.0.0
[ 29.580727] hm2/hm2_5i25.0: Remote setup failure on instance 0
[ 29.580737] hm2/hm2_5i25.0: failed to parse Module Descriptor 4
[ 29.580758] hm2_5i25.0: board fails HM2 registration
[ 29.580835] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 40.498469] hm2: unloading
[ 42.803296] RTAI[math]: unloaded.
[ 42.808741] SCHED releases registered named ALIEN PEDV$D
[ 42.824242] RTAI[malloc]: unloaded.
[ 42.924075] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 42.929150] I-pipe: head domain RTAI unregistered.
[ 42.929299] RTAI[hal]: unmounted.
Sure hope I didn't damage my 7i77...
RTAI is loading and happy.
5i25 is reporting for duty.
The smart-serial port 0 channel 0 is not working properly. That is GPIO on the 7i76, I am not sure what it is on a 7i77.
So, it does seem that you might have damaged the 7i77.
Try sserial_port0=x0xxxxx in the loadrt to disable channel 0 and see what happens.
I already checked the field power is 24V. It comes from one of the Maho's rails, and is still fine.
Disabling the channel 0 results in errors where the HAL includes 7i84 pins, which is about what would be expected. I suspect if the load errors out on pin names, then it has successfully completed the MESA hm2_pci load. So deactivating the 7i77 "corrected" the initial fault. That does imply that the fault is in the 7i77. Bugger. Is there any way to use MesaFlash to troubleshoot that further?
Mark
