Retrofiting an old big milling machine
10 Jul 2018 19:08 #113966
by vre
Retrofiting an old big milling machine was created by vre
Hello
I have found this old bulgarian cnc milling machine for 1500 euros.
It has some problem with electronics..
Is suitable for retrofiting ?
Can you reply me quickly because i must buy it before other one get it.
Thank you.
Thank you.
10 Jul 2018 20:50 #113968
by Grotius
Replied by Grotius on topic Retrofiting an old big milling machine
VRE,
I think you can better leave the machine over there. It has to be disambled and totally rebuild if you want to get money.
It leaks oil....
300 euro i would try it.
It leaks oil....
10 Jul 2018 21:01 #113970
by vre
Replied by vre on topic Retrofiting an old big milling machine
thank you for your reply..
oils maybe is cutting fluid oil.. What do you think about that?
The machine is more than 2 tons and gives me with it 10 iso50 toolholders.
I have not access to machine to inspect it because it is far away from me.
Servo drivers in these machines (from 1990s) accept analog +-10V ?
- Thank you received: 5934
10 Jul 2018 21:26 #113972
Replied by tommylight on topic Retrofiting an old big milling machine
I would buy it for that money for sure.
Then again i have a machine fetish !!!
11 Jul 2018 17:27 #114017
by vre
If you give it at scrap metals they give 450 euros sold as iron.
So he will not give me the machine for 300 because scrap shops give to owner 450 sold as iron by kilos.
I think i will buy it comes with 12 iso50 tool holders and motors are ok.
i will try to reduce the price to 1000 but iam not sure if the owner accept that...
VRE,
It leaks oil....
11 Jul 2018 17:54 #114018
by OT-CNC
Replied by OT-CNC on topic Retrofiting an old big milling machine
I would make the time to go inspect it. Bring and indicator and check play on all axis even if it doesn't power up. Check spindle too. You should be able to get an idea of the condition it's in. May or may not be worth getting.
11 Jul 2018 19:47 #114023
by vre
Cost to go for inspection is the same as machine so it is impossible..
I need your opinion from the photos...
11 Jul 2018 20:17 - 11 Jul 2018 20:21 #114025
by Grotius
Last edit: 11 Jul 2018 20:21 by Grotius.
11 Jul 2018 20:34 #114026
by OT-CNC
I would take the deckel looking thing over a non cnc'd Bridgeport. Any machine with the ballscrews already fitted is key.
11 Jul 2018 20:38 - 11 Jul 2018 20:42 #114027
by OT-CNC
Actually, looking at the deckel like mill pictures again, I don't see a shaft coming out of the table? Screw missing or just burried in the casting?Where is the x axis motor?
Last edit: 11 Jul 2018 20:42 by OT-CNC. Reason: deckel
Moderators: piasdom
Time to create page: 0.092 seconds
