Retrofiting an old big milling machine
08 Jan 2021 09:29 #194474 by andypugh
The handwheels in the front are indepedent from motor
so i can use the dc motor for z axis(permanet engaged electromagnet for z)
and put in the front 2 servomotors for x and y axis but these will have serious backlash.
That would be the best solution. Though I do find the puzzle of how to configure a single-motor machine to be more technically interesting.
Has linuxcnc some option for backlash removal in linear movements ?
It has, but the results with milling machines are not always good. The problem is that the system has no way to predict the direction of the cutting forces, only the direction of movement. It can work very well with lathes.
In theory, with glass scales, backlash compensation is automatic.
Are you sure that the machine does not have ballscrews? It would be very unusual for any CNC machine not to have them. They were becoming fairly common on manual machines at about the point that CNC started to come in to use.
10 Jan 2021 22:36 #194793 by vre
It has leadscrews also if i put the motors in the position of handwheels
it will have backlash from reduction gears plus backlash from leadscrew nuts.
I have read somewhere what you can pure inside leadscrew some material
like moglice and fix the backlash plus this material has lower friction than bronze nut.
11 Jan 2021 02:00 #194842 by OT-CNC
I have done moglice nuts and they work surprisingly well if the screw is not worn too much. Ball screw is a better option in general.
If you want to go the moglice route, I would check with your supplier on pricing. It's not cheap. It's a system (type for nut/bearing FLP, I think it was) and you need to get the release wax they recommend and lapping compound that does not imbed. Timesaver yellow is what I used.
The process in a nutshell is to bore out the old nut, place it on the least worn section of prepared/waxed screw, fix it radially concentric to screw, seal and cap the openings and fill with moglice through a low point fill port. You'll need a vent and dam at the high point to capture excess resin. You want to fill it with minimal chance of trapping air. Make sure there are no leaks as the resin takes some time to gel and it can run out of the nut housing if you're not careful. When set, you have to break it free from the threads which should work okay if screw was waxed. Final lapping in place will get it to the feel you want.
The following user(s) said Thank You: vre
11 Jan 2021 12:38 #194892 by johnmc1
I have made (many years ago) a new lead screw nut but the backlash is still there in the worn section.
A new lead screw and nut fort he lathe reduced almost all the backlash.
The ball bearing nut block and ball shaft have very little friction an almost nil backlash. The time required to try and repair the lead screw / nut,if it is possible to fit a ball screw system, is not worth the effort .
Cheers john
11 Jan 2021 14:24 #194911 by andypugh
[quote="johnmc1" post=194892The time required to try and repair the lead screw / nut,if it is possible to fit a ball screw system, is not worth the effort[/quote]
It made more sense before the advent of cheap chinese ballscrews.
One potential reason to make a polymer nut might be a lack of space. Ballnuts are always bigger than plain nuts.
One cheap and easy possibility:
www.denfordata.com/bb/viewtopic.php?t=3727
(The original link does not seem to contain the information any more)
11 Jan 2021 15:08 #194915 by OT-CNC
Interesting link there Andy. I'll have to try that sometime just for experimentation.
12 Jan 2021 04:49 - 12 Jan 2021 04:55 #195011 by vre
The leadscrews for x/y are 32mm and for z 65mm so are thick
ballscrews of this diammeter will have a serious cost also the ballnut is more bulky.
If put thinner ballscrews than leadscrews for example 25mm for x/y and 50mm for z
to have space for ballnut mounting and reduced cost will be ok?
Because it is knee mill the table up/down is z axis and table is about 1000+ kg
the weight force eliminates the z axis backlash ballnut automatically?
@OT-CNC which was your moglice supplier? What is the price?
I have not found a moglice supplier yet.
Last edit: 12 Jan 2021 04:55 by vre.
12 Jan 2021 13:37 #195048 by andypugh
I would expect so.
I initially planned to keep the acme screw on the Z of my manual-to-cnc conversion milling machine, but I found that my servos could not turn the nut (and the space for larger pulleys was limited)
I would expect a 25mm ballscrew to be adequate for the other axes.
The difference in price for the screw between 32 and 25 is not huge. In fact at this store the 32 is cheaper:
www.automationshop.co.uk/scr3205-tbi-5mm...llscrew-spindle.html
www.automationshop.co.uk/scr2505-tbi-5mm...llscrew-spindle.html
There is some difference in nut prices (but not huge)
www.automationshop.co.uk/sfnur03205t4d-s...205-ballscrew-1.html
www.automationshop.co.uk/catalog/product/view/id/109156
63mm diameter, though, are a completely different sort of price. Literally 100x as expensive for the screws.
12 Jan 2021 15:28 #195067 by OT-CNC
In the US, I get it from Devitt.
It's a German product if I recall correctly. Diamant polymer in Germany or maybe others in Europe sell it??
You'll have to check with them on cost.
Before you go that route inspect your screws carefully. Stone and polish any high spots/ nicks on the od and threads. When you cast the material it basically locks in. Any irregular high spot will bind during lapping. The wax layer is critical. It controls to some extent how much play the nut will have prior to lapping and allows you to brake it free. If you over apply, you have play, under apply and the nut is very difficult to brake free. If you need more details, I can dig into it deeper...
12 Jan 2021 15:44 #195071 by andypugh
www.diamant-polymer.de/en/products/moglice/
Actual suppliers seem more elusive. Perhaps they only sell direct?
A possible source in the UK seems to be
www.pesukltd.com/products/industrial_pro...chine_tool_industry/
Moderators: piasdom
Time to create page: 0.092 seconds
