Anilam 1100M to linux cnc
09 Jun 2020 19:41 #170854
by robf100
Anilam 1100M to linux cnc was created by robf100
Hello, this is my first time installing linux cnc (6i25 and 7i77D to Anilam 1100M retrofit) and I'm have a little bit of trouble. I have all my axis figured out and wired up. Right now I am trying to get my spindle all wired and I am very lost at this point. Some sleep would help, but so would your opinion. I have a Saftronics PC3 VDF for spindle control (The VDF that yaskawa made a million of under different names) but I am lost on where the the wires match up to my 7i77D. Looking for help, the pins I am occupying on the VFD are pins 1, 2, two in pin 6, 8, 11, and FLT -B & -C. Those are all the pins that led to the original distribution board. imgur.com/gallery/khvM4PS
09 Jun 2020 20:04 #170857
Replied by PCW on topic Anilam 1100M to linux cnc
1 FWD --> 7I77D field output
2 REV --> 7I77D field output
6 COM --> 7I77D field power common
8 FREQ REF --> 7I77D AOUT5
11 COM --> 7I77D AGND5
FLT-C --> 7I77D +field power
FLT-B --> 7I77D field input
- Thank you received: 5962
09 Jun 2020 20:05 #170858
Replied by tommylight on topic Anilam 1100M to linux cnc
Mesa TB5 >>>>VFD
21 >>>>>>>>> 6
22 >>>>>>>>> 1
In case the spindle stays on, reverse the above 2 pins.
23 >>>>>>>>> 11
24 >>>>>>>>> 8
That is for forward only, in case you need reverse it is better to use two outputs from Mesa 7i77D and wire them to pins 1 and 2 on the VFD, but that would require wiring 7i77D ground to pin 6 on the VFD, so might be much better to use two relays for that.
The VFD manual says that the inputs 1 and 2 are optically isolated but it does not say that for the common pin 6. It should be isolated and that can be checked with a DVM/multimeter, but it is safer to use relays.
21 >>>>>>>>> 6
22 >>>>>>>>> 1
23 >>>>>>>>> 11
24 >>>>>>>>> 8
10 Jun 2020 18:04 #170982
by robf100
Replied by robf100 on topic Anilam 1100M to linux cnc
Thanks, I have forward all wired up with a relay this morning. Should be able to test here soon. What about FLT -B and -C? Wire them up to field power and one of the board inputs? I don't really comprehend what those two wires are for
10 Jun 2020 19:29 #170988
FLT = fault
That is a fault output from the drive to the Mesa board, so you can set that in hal to stop the machine and alert to what drive exactly caused the error.
10 Jun 2020 21:48 #171002
by robf100
Oh, makes sense. And would it be ok if I established a connection with you for simple questions? The mill is about 90% wired up and now I'm just stumbling through the finishing steps
11 Jun 2020 00:05 #171017
And connections here on this forum do nothing that is useful.
To whom was this addressed?..........would it be ok if I established a connection with you for simple questions? ..........
11 Jun 2020 07:45 #171089
by bbsr_5a
Replied by bbsr_5a on topic Anilam 1100M to linux cnc
on the Woodrouter i connected the FLT signal to pause not e-stop as somtimes on Hardwood the error ocours sa the bit cand cope on chipping Quick look at the machine and (S) go one
Moderators: piasdom
Time to create page: 0.157 seconds
