- Hardware & Machines
- Milling Machines
- Wells Index Analog Amplifiers, DC Permanent Magnet servo W/Tach, Resolvers...
04 Aug 2020 22:11 #177294
Resolvers work fine, and are tougher than encoders.
I have been known to remove an encoder from a motor and fit a resolver.
A Mesa 7i49 is all you need to interface the resolvers and control the analogue amps.
Replied by andypugh on topic Wells Index Analog Amplifiers, DC Permanent Magnet servo W/Tach, Resolvers...
For the 750 I am leaning towards removing the analog amps and going to a step and direction system and swaping the resolvers to encoders. I have a friend at Rockwell looking into the Electrocrafts for some specs on them.
04 Aug 2020 22:55 #177297
by CORBETT
@riversvic
There is the answer you needed... If Andy says they work then they do.
I just haven't ever messed with them in the past, but that would be the easiest way. You simply interface with the Mesa board and you will be up and running quicker than changing everything out, much easier than the hardware change, plus cheaper.
I believe you are closer than you think on getting it running.
Replied by CORBETT on topic Wells Index Analog Amplifiers, DC Permanent Magnet servo W/Tach, Resolvers...
@riversvic
05 Aug 2020 23:29 #177440
by riversvic
Replied by riversvic on topic Wells Index Analog Amplifiers, DC Permanent Magnet servo W/Tach, Resolvers...
I guess I need to try to sort out what the inputs to the amps are...
Moderators: piasdom
- Milling Machines
Time to create page: 0.071 seconds
