- Hardware & Machines
- Milling Machines
- Cincinnati Milacron 20 V 5-AXIS PROFILER Electrical Manual/ Alarms codes etc
20 Jan 2021 17:28 #196009
by OskarVL
Hi
I'm new, working on this machine, above all i have not any manual to get orientation about the electrical on this model
Cincinnati Milacron 20 V 5-AXIS BRIDGE TYPE VERTICAL PROFILER WITH ACROMATIC A950
So, if you have a manual to send me or sell me please will be helpfully.
The alarms codes was showed in screen is following.
ALERT CODE 18189 - MOTOR OVERLOAD SCAVENGER
ALERT CODE 03169 - ? AXIS END PT RANGE LIMIT
thanks ind Advance
OskarVL
thanks ind Advance
OskarVL
- Thank you received: 5961
21 Jan 2021 17:25 #196116
Replied by tommylight on topic Cincinnati Milacron 20 V 5-AXIS PROFILER Electrical Manual/ Alarms codes etc
Last error seems like one of the axis is on a limit switch.
No idea what a scavenger does on a motor.
Not much info on the net, this is all i could find:
websystem.gismo.se/gismo/files/859/859.d...erating%20manual.pdf
And some other less useful ones.
21 Jan 2021 18:35 #196125
by scotth
Replied by scotth on topic Cincinnati Milacron 20 V 5-AXIS PROFILER Electrical Manual/ Alarms codes etc
Do you have a scavenger pump on the head to pull lube oil out of the head? Normally a small gear pump to avoid the head filling with oil.
21 Jan 2021 21:20 #196148
Thanks, i was not aware of such a thing.Do you have a scavenger pump on the head to pull lube oil out of the head? Normally a small gear pump to avoid the head filling with oil.
22 Jan 2021 00:14 #196164
by scotth
Large mills tend to use hydraulic oil for gearbox lube. Fed from the hydraulic pump through distributor blocks. Failure to remove the oil is obvious in an hour or two.
23 Jan 2021 00:03 #196298
Replied by andypugh on topic Cincinnati Milacron 20 V 5-AXIS PROFILER Electrical Manual/ Alarms codes etc
There are a couple of those monsters running LinuxCNC in Wichita.
26 Jan 2021 17:10 #196637
SWS sent me this PDF which might help:
Moderators: piasdom
- Milling Machines
