Anilam 1100M Servo Bearings
10 May 2021 17:24 - 10 May 2021 17:25 #208491
by BigJohnT
Anilam 1100M Servo Bearings was created by BigJohnT
My X axis on my BP with an Anilam 1100M CNC conversion on it started to rattle like a bearing is bad. I got the shaft end bearing off and it's fine naturally it's the encoder end bearing which for the life of me I can't figure out how to get that black part off so I can remove the coupling for the encoder. I'm assuming the black thing is a resolver or something... so if anyone has any ideas I'm all eyes.
JT
JT
Last edit: 10 May 2021 17:25 by BigJohnT.
10 May 2021 18:18 #208495
by BigJohnT
Replied by BigJohnT on topic Anilam 1100M Servo Bearings
I got the plastic cover, the coupling and the tacho off but it's not making sense to me at this point... the bearing if the ID is bigger than the tacho windings would be pretty big. It looks like the tacko windings are pressed onto a very small shaft? No, the encoder shaft is pressed into the end of the servo shaft.
JT
JT
10 May 2021 19:04 #208498
by BigJohnT
10 May 2021 21:51 #208502
by BigJohnT
Well that was an excuse to buy a bearing separator from horrible freight. Bearings are out and will be here tomorrow.
JT
JT
- Thank you received: 5934
10 May 2021 23:44 #208509
Replied by tommylight on topic Anilam 1100M Servo Bearings
Nice monologue !
Glad you got it figured out, i would have not been much help.
11 May 2021 01:51 #208513
by OT-CNC
Replied by OT-CNC on topic Anilam 1100M Servo Bearings
What puller did you end up getting? Was it difficult to grab the bearing without damaging the commutator?
I got the older SEM motors and probably will have to do the same thing at some point.
11 May 2021 11:53 - 11 May 2021 11:56 #208537
by BigJohnT
The bearing came right off with no damage to the commutator.
I used this bearing seperator from Horrible Freight.
The real scary part was putting my puller on the brush housing and pulling it and the tacho windings off at one time, but the tacho windings were not very tight on the shaft so it came off without using a wrench on the pulling screw.
I'll have new bearings this morning so I can reassemble it before I forget how... however the shaft seal won't be here till Friday.
JT
JT
Last edit: 11 May 2021 11:56 by BigJohnT.
The following user(s) said Thank You: joekline9
11 May 2021 13:39 #208548
by OT-CNC
Thanks for the info. I'm glad it worked out relatively easily.
11 May 2021 21:58 #208589
by BigJohnT
Well I put the servo back together this evening but when the drive comes on line the shaft spins real fast for a second then power is off in LinuxCNC....
Well I have till Friday to figure it out when the shaft seal arrives...
JT
JT
11 May 2021 22:55 #208597
by OT-CNC
Any chance the tacho wiring is reversed?? Runaway?
Moderators: piasdom
Time to create page: 0.271 seconds
