Anilam 1100M Servo Bearings
11 Jun 2021 17:25 - 11 Jun 2021 17:37 #211818
by BigJohnT
Replied by BigJohnT on topic Anilam 1100M Servo Bearings
Well I built a voltage divider circuit based on
this calculator
and used a 33 ohm for R1 and a 560 ohm for R2. Without the resistors I get 9.0v across R2 I don't get the expected 8.5v instead I got 6.5v. Checking my resistors and the 33 ohm meters out at 30 ohms and all my strips of resistors are marked with the value... the 560 ohm resistor measured out at 126 ohms! Well so much for trusting that I had them marked correctly... going to see what I can find in my resistor box and try again.
Edit: oddly enough all the rest of the resistors in that strip measure around 560 ohms... go figure.
Edit: with a 560 and 30 ohm I get 7v not the 8.5v the calculator said I'd get...
JT
JT
Last edit: 11 Jun 2021 17:37 by BigJohnT.
11 Jun 2021 18:50 #211828
by BigJohnT
After doing some putzing around on the bench with 24v and 48v power supplies and measuring tacho voltages I plugged the new servo into the X axis drive and for some unknown reason it rotated a 1/4 turn in the minus direction and stopped so I dialed the MPG in the plus direction and then just started working fine in both directions... now to remember how to setup halscope.
JT
JT
- Thank you received: 5934
11 Jun 2021 19:56 #211829
Replied by tommylight on topic Anilam 1100M Servo Bearings
Nice.
13 Jun 2021 19:56 #211965
by BigJohnT
X still faults out from time to time so I'm running an exercise program for the X axis until it runs all the way through a couple of times I'm not going to try and cut anything.
JT
JT
13 Jun 2021 22:50 #211975
by BigJohnT
I finally figured out what the issue is, one of the armature wires was rubbing on the encoder coupling. Too bad it took out the Drive when if finally shorted enough to make a pop...
JT
JT
18 Jun 2021 22:55 #212365
by BigJohnT
Got the replacement drive in today and oh my it was covered with some fine sparkly stuff. I spent a couple of hours with a soft tooth brush and an artist brush cleaning that stuff off. I could not even setup the board until I cleaned it. Put it in and it runs like new!
JT
JT
Moderators: piasdom
Time to create page: 0.155 seconds
