Using factory RPM sensor/encoder
11 Jan 2022 14:53 #231449
by jlm123
Using factory RPM sensor/encoder was created by jlm123
Hello:
I am currently in the process of converting a PM-940V to a CNC machine. Is it possible to use the factory spindle sensor as the spindle encoder, and is it possible to have it send data to the factory rpm display and the mesa board simultaneously?
Machine specs:
Mesa 7i76e board
Stepperonline CL-86Y drivers and motors
Machine specs:
Mesa 7i76e board
- robertspark
- Thank you received: 216
11 Jan 2022 19:19 #231474
by robertspark
Replied by robertspark on topic Using factory RPM sensor/encoder
is it an encoder or an rpm (single pulse per rev pulse) sensor?
do you have a photo of the sensor
11 Jan 2022 19:50 #231477
by jlm123
Replied by jlm123 on topic Using factory RPM sensor/encoder
I can get photos over the weekend.
I'm not sure what type of sensor it is.
- robertspark
11 Jan 2022 21:02 #231480
by robertspark
a photo will help as there is quite a difference from an encoder to a simple rpm sensor.
the encoder will provide the exact position and the rpm sensor just 1 pulse per rev.
it may be possible to share a common sensor but you will need to find out some details on the sensor (such as it's output signal voltage, 5v, 12v ????)
if it were me, I'd use a couple of simple circuits so that the input impedance of the two devices is not an issue.
more details required first
31 Jan 2022 15:57 #233645
by jlm123
So I'm going to use a hall-effect switch as my rpm sensor. The spindle has 4 magnets on it (I decided to not use the factory one so I can keep the factory display and to not have weird multiple supply issues)
I'll update again after this weekend,.
03 Oct 2022 19:39 #253374
by jlm123
Ok, maybe not update that weekend.....
I ended up gluing a magnet to the spindle for the sensor (so there are separate sensors for the mill display and the CNC computer)
I've recently replaced the computer and switched to probe basic, so now I have to get Probe Basic to see the sensor speed (had it working in QTDragon)
Moderators: piasdom
