Using CNC Mill in "Manual" mode
- hunterlong
07 Mar 2023 20:31 #266057
by hunterlong
Using CNC Mill in "Manual" mode was created by hunterlong
Hey all,
I've had a lot of fun learning a few basic G codes (mainly G01) and using my CNC mill in manual mode. However, one thing that I don't understand. Is there anyway to cancel a movement before it is finished executing?
Say that I type into MDI "G01Y10F5" which should move to y=5in with a feedrate of 5 inches per minute. What if part of the way through the cut I want to stop the movement. Is there a command I can type to do this, other than pressing the E-stop?
Thanks,
-Hunter
Thanks,
-Hunter
- Thank you received: 6268
07 Mar 2023 21:34 #266070
Replied by tommylight on topic Using CNC Mill in "Manual" mode
Press "ESC".
- hunterlong
09 Mar 2023 01:39 #266166
by hunterlong
Replied by hunterlong on topic Using CNC Mill in "Manual" mode
Haha, wow that is great. Should have tried that.
Thanks Tommy!
-Hunter
Thanks Tommy!
-Hunter
09 Mar 2023 03:04 - 09 Mar 2023 03:06 #266179
Yeah, sorry for the extreme amount of info contained in that message, i was busy but i thought better than nothing.
Edit:
Almost forgot, there is a typo in your original message:
Say that I type into MDI "G01Y10F5" which should move to y=10in with a feedrate of 5 inches per minute.
Edit:
should be:Say that I type into MDI "G01Y10F5" which should move to y=5in with a feedrate of 5 inches per minute.
Last edit: 09 Mar 2023 03:06 by tommylight. Reason: more info
Moderators: piasdom
