Rigid tapping with simple encoder
- Stanislavz
- Thank you received: 15
16 Sep 2023 17:18 - 16 Sep 2023 18:56 #280936
by Stanislavz
Rigid tapping with simple encoder was created by Stanislavz
Hello. One simple question - is it possible to tap on cnc mill having simple encoder. I did added it to phase A - it outputs correct rps of spindle if seen using hal meter. But index goes only positive if look into its parameter.
I did this also to make closed loop of rpm of spindle - i do have variator between motor and spindle.
Now i got 6.48 impulse per rotation - 18 magnets on lower gear intermediate pulley with 50 tooth, while pulley on spindle have 18 tooh too. I could make it quadrature, but i still have only one spare input pin on parport.
Thank you !
Thank you !
Last edit: 16 Sep 2023 18:56 by Stanislavz.
16 Sep 2023 18:19 #280939
Replied by PCW on topic Rigid tapping with simple encoder
Typically you need both quadrature and an index input for rigid
tapping because the Z axis motion needs to be synchronized
with spindle rotation even as the spindle reverses direction.
The following user(s) said Thank You: Stanislavz
- Stanislavz
16 Sep 2023 18:58 #280945
by Stanislavz
Replied by Stanislavz on topic Rigid tapping with simple encoder
How does emc2 takes not rigid tapping ? Or it still needs all three signals ? I have some weird float tap holder.
- Thank you received: 5942
16 Sep 2023 22:44 #280952
Replied by tommylight on topic Rigid tapping with simple encoder
The one where the spindle spins on in one direction while the tap spins CW going down and CCW going up ?I have some weird float tap holder.
- Stanislavz
17 Sep 2023 07:11 #280984
by Stanislavz
Which extends telescopically. But does not have any spring to hold in middle position. Will make some photos.
I will ask a different.
Now, i do have encoder. 6.48 pulse per turn. Example. 10mm depth thread, 1mm pitch thread.
I go to reqested xyz coordinates, turn on spindle cw, and feed z at 100/648 each pulse till 65 pulses count. Then ccw till 66 pulses count. And feed z same as before.
Which shell work with float tapping.
- Stanislavz
19 Sep 2023 11:36 #281154
by Stanislavz
Some more head scratching. I think i will go this way:
pico-systems.com/bridge_spindle.html
+ just add one sensor with missing tooth (hole drilled in tooth center/ centers)
Or one still need both Phases A + B and index for riggid tapping ?
Moderators: piasdom
Time to create page: 0.167 seconds
