error message
14 Mar 2011 21:18 #7833
by Steveb
error message was created by Steveb
Hello
I'm new to Linus, I'm using Umbuntu 8.04 that was allready setup in the computer from sherline and the post was setup by Bobcadcam.
When I run the program the following message comes up "bad character '134682144. Anyone know what it is and also is there a list of error messages?
Thanks for your help
steveb
steveb
14 Mar 2011 21:26 #7835
by BigJohnT
Replied by BigJohnT on topic Re:error message
Yes that is an error in the g-code file no doubt created by bobcram.
Do a search for that string with your favorite text editor and you should find the offending line.
15 Mar 2011 00:02 #7843
by Steveb
Replied by Steveb on topic Re:error message
I'll keep on looking
steveb
steveb
15 Mar 2011 00:07 #7844
by BigJohnT
Oh, to answer your other question, no there is not a list of error messages as it would be impossible to maintain. The developers try there best to not make the message cryptic... but sometimes they are a bit at first.
15 Mar 2011 12:31 #7849
Replied by andypugh on topic Re:error message
Steveb wrote:
Is there a line number given? (I assume that isn't the line number!)
I think "Bad character" can mean an axis-word for an axis you don't have. Axis words are XYZABCUVW.
15 Mar 2011 13:13 #7852
by BigJohnT
Usually the message contains more info like
Near line 2 of ...file name
error message
error message
15 Mar 2011 18:47 #7860
by Steveb
I found that bobcadcam puts four numbers after the f speed , so I changed that but didnt help. From what I have been reading the codes seems to look ok.
15 Mar 2011 19:05 #7861
Attach the G-code to a message and we can have a look at it?
16 Mar 2011 02:05 #7871
by Steveb
I dont know how to put line numbers in, when I go to settings and check line number it wont put line numbers in.
16 Mar 2011 02:11 #7872
by Steveb
Ill give it a try tomorrow night, im knew to this forum and have never made an attachment
Moderators: piasdom
