Forum Header
Mach 3 conversion to Stepconf Wizard
27 Apr 2015 23:58 - 28 Apr 2015 00:24 #58167
by cgboehm
Replied by cgboehm on topic Mach 3 conversion to Stepconf Wizard
Will you convert mine too? Thanks!
-Cole
-Cole
Last edit: 28 Apr 2015 00:24 by cgboehm.
The topic has been locked.
13 May 2015 13:19 #58618
by dazza0101
Replied by dazza0101 on topic Mach 3 conversion to Stepconf Wizard
Will be extremely grateful if you can convert this one for me please. I don't know where I was going wrong the last time I tried, but just couldn't get it to work.
26 May 2015 03:15 #59031
by Serpentus
Replied by Serpentus on topic Mach 3 conversion to Stepconf Wizard
Hi BigJohnT, Could you please convert my file also? (Maybe you forgot to do it before xD). If you can't, then thanks anyways, but please tell me to format that partition and use it for something else..
It's a Syil x7 plus from the year 2014 with 4 axis, XYZA. (Just adding the model and year just in case someone has the same machine and also wants the file).
The Mach3 configuration is in metric by the way.
Thanks a lot!
Thanks a lot!
01 Jun 2015 09:27 #59290
by palmfans
Replied by palmfans on topic Mach 3 conversion to Stepconf Wizard
Hi John, could you help convering the MX4660 Mach 3 file for me.
Thanks a lot.
palmfans
Thanks a lot.
palmfans
- racedirector
- Thank you received: 41
08 Jun 2015 19:57 #59623
by racedirector
Replied by racedirector on topic Mach 3 conversion to Stepconf Wizard
Hi there BigJohnT
Would appreciate the conversion of my Mach3 settings, I have included the 2 I use in the zip, the main and mostly used one is the metric one (Mach3 doesn't play nicely just using G20/G21)
Cheers
Bruce
Cheers
Bruce
12 Jun 2015 13:13 #59739
by Marfil
Replied by Marfil on topic Mach 3 conversion to Stepconf Wizard
Hi. Cuold I send you my xml file? Thanks a lot.
12 Jul 2015 21:01 #60587
by escott
Replied by escott on topic Mach 3 conversion to Stepconf Wizard
Hello John,
Please could you convert a Mach 3 Denford Easiturn config for me.
Thanks,
Edward
Thanks,
Edward
29 Jul 2015 11:23 #61008
by golem
Replied by golem on topic Mach 3 conversion to Stepconf Wizard
Hi!
Would you like to make conversion for me?
hank you,
Daniel
hank you,
Daniel
29 Jul 2015 18:03 #61014
by BigJohnT
By any chance are you using the yet to be released 2.7 version? My conversion program is now part of the Stepconf Wizard thanks to Chris.
JT
Replied by BigJohnT on topic Mach 3 conversion to Stepconf Wizard
Hi!
hank you,
Daniel
JT
30 Jul 2015 02:30 #61022
by golem
Thank you for answer.
I made fresh installation of 2.7 version.
I started Stepconf and there wasn't option to import mach fconfiguration...
I would be grateful for making me a conversion.
Time to create page: 0.156 seconds
