Forum Header
Unexpected waveform results
11 Mar 2013 15:56 #31205
by Rick G
Replied by Rick G on topic Unexpected waveform results
Glad you got it sorted out.
You might want to give more details of your solution to help others in the future.
Rick G
Rick G
15 Mar 2013 14:27 #31440
by rip1980
Replied by rip1980 on topic Unexpected waveform results
Stumbled upon your problem researching something else.
Making the level shift is pretty trivial, and while this is not an IC, it's cheap enough that making it yourself is probably not worth your time. You mentioned arduino, so are probably familiar with sparkfun:
www.sparkfun.com/products/8745
Simple mosfet shifter, your application would just need TX LV on the port side and TX HV on the controller side, plus power. Each board can do 2 pins, the RX feature (which is um, not very good IMHO looking at the schematic) is unused.
You still get to hack up a wallwart and add a couple linear regulators (3.3V and 5V, add a couple caps for filtering for good measure if you like.)
If you simply must get an IC and make a board, etc, look at CD40109.
Time to create page: 0.244 seconds
