Forum Header
Newbie questions... be gentle...
09 Mar 2013 01:47 - 09 Mar 2013 01:49 #31105
by muddbog
Replied by muddbog on topic Newbie questions... be gentle...
I've already found the IC I'm going to use. its from TI and I have a free sample of it on the way. it costs $14 each just for the IC and these are good enough to run the biggest Nema 52's. just so I can upgrade later if I needed to...
I'm looking at using a 7a nema 34's ST8918D6708
de.nanotec.com/schrittmotor_st8918.html
Last edit: 09 Mar 2013 01:49 by muddbog. Reason: displayed wrong way
09 Mar 2013 16:04 #31122
by Rick G
For more I/O's you could look at Mesa 5I20 / 5i25.
Rick G
Replied by Rick G on topic Newbie questions... be gentle...
No misunderstanding, for Linuxcnc usb is not a current solution.also I heard that there was some problem with usb as far as the way Linuxcnc uses "realtime" but I could have misunderstood...
Rick G
The following user(s) said Thank You: muddbog
09 Mar 2013 16:19 #31124
by muddbog
Yea I was checking out what Mesa has to offer. I think the 5I25 would suit my needs perfectly. As far as the manual controls, sensors, e-stop, etc I should be able to run those through USB if I'm not mistaken.
Don't get me wrong I totally understand why USB won't work with the Stepper motors but it would be nice if we could just go through USB for everything. Plus now days we have USB 3.0 on the newer computers like my retina Macbook, I think with 3.0 the latency wouldn't be too bad.
What are your thoughts?
Thanks Rick
Thanks Rick
09 Mar 2013 20:45 #31133
by ArcEye
Replied by ArcEye on topic Newbie questions... be gentle...
Hi
If you search USB on the forum you will find chapter and verse on it and why it is not suitable for software step generation stepper control.
USB does not work with windoze and Mach either, it is just that they use external smooth-stepper boards to generate the pulses
You must not confuse port speed with latency, the throughput of a USB 3 port is miles faster than a parallel port but it still suffers from the same problems regards latency.
09 Mar 2013 22:21 #31137
by Rick G
Yep.
Might look at Simple remote pendant
and Hidcomp
hidcomp.sourceforge.net/
Just to get an idea of what can be done.
Rick G
Yep.
and Hidcomp
Rick G
26 Apr 2013 04:15 #33218
by manfredv
Replied by manfredv on topic Newbie questions... be gentle...
As to your desire to use USB - don't.
It is not a question of hoe LinuxCNC handles USB ports it is the way your PC handles them and it can be (quite literally) pretty dangerous or at the least expensive. In layman's terms USB ports are not as responsive as the parallel port which means that your mills or lathe cannot be controlled as fast as is necessary because there is significant lag in when an output can change state, so it is quite possible that a command to raise the spindle will be received too late, causing the tool to crash into the material, wrecking your workpiece or worse.
Time to create page: 0.087 seconds
