Forum Header
Trying to find pinout info?
- customcutter
08 Apr 2013 22:09 #32434
by customcutter
Replied by customcutter on topic Trying to find pinout info?
I'm loving linux already.
I looked every where that I thought I might have a spare cat5e cable. Nothing except assorted TV cables, cat5 cables, etc. Finally decided I would unplug one from my server, and there was a 6' laying behind the server unused. Moved the CPU/screen back to the computer room. Plugged everything in and BINGO. I'm trying to find out how to connect to the internet and UPDATE MGR pops up on the screen. It's presently updating 172 files.
Did I already say
thanks,
Ken
Did I already say
thanks,
Ken
08 Apr 2013 22:38 #32436
by BigJohnT
Replied by BigJohnT on topic Trying to find pinout info?
I'm glad it is coming together for you now!
- customcutter
09 Apr 2013 23:39 #32491
by customcutter
OK updated linux, did not install 12.04. I'm assuming it updated to 2.5.1 or 2.5.2.
Downloaded Chris's zip file and extracted it.
I'm starting over at Chapter 4 of Getting Started Manual. (Spent 4 hours in dentist chair yesterday).
Gecko 201's don't have 2 micro steps per step do they? ( I guess I can reconfigure later if they do?)
Ken
Ken
- customcutter
10 Apr 2013 00:13 #32493
by customcutter
OK skipped the stepconf wizard, that's for parallel ports, correct?
Moved to the pncconf wizard, selected the 5i25, unchecked the 7i33 sanity check. Moved on to the pin configuration for the 7i76.
The only tabs it is showing is for TB4, TB5, and TB6.
The only leads I have connected to the 7i76 are on TB1 (field power 24VDC from transformer and bridge full wave rectifier), and TB2 (STEP0-,DIR0-, and +5VP from Gecko 201 drives) for 4 Axis's. Am I missing something here? All the other Gecko pins are wired from the board they are mounted on, I simply pulled of step, dir, and 5V+ to go to 7i76?
I can't even find a tab for the TB1, TB2, or TB3 terminal blocks.
thanks,
Ken
thanks,
Ken
10 Apr 2013 02:54 #32499
by BigJohnT
Press the Help button to see how Chris numbered things.
It's a bit confusing but the stepgens are on I/O Connector 3... the correctly named terminal blocks for the I/O is on the Smart Serial 0 tab... I assume I/O Connector 2 is the unused second connector on the 5i25 card so ignore it.
- customcutter
10 Apr 2013 04:25 #32504
by customcutter
A bit confusing... I still haven't found anything refering to TB1 and TB2...only TB4, TB5, and TB6 on the Smart Serial 0 tab.
I've read all of the help pages on each step of the pncconf. I've reread this thread several times and reread Chris's thread and the one that was linked in it. Also read the 7i76 daughtercard manual. It ain't coming together right now. Maybe the pain killers from the dental work. I'll try again in the AM.
On a side note I found a note (page2 of 7i76 manual) about the 7i76 running in setup or operate mode depending on where the W3 jumper is set. I don't have the "controller" hooked up because the computer is back in the house. Do I need to hook up the "controller" and set the W3 jumper so that it can configure itself????
Ken
Ken
10 Apr 2013 22:12 #32528
No, definitely not. W3 is only for flashing new firmware to the 7i76. You are very unlikely _ever_ to need to do this.
Replied by andypugh on topic Trying to find pinout info?
- customcutter
10 Apr 2013 23:56 #32538
by customcutter
Andy:
thanks,
Ken
thanks,
Ken
Time to create page: 0.235 seconds
