Forum Header
stop and go while homing
13 Jun 2013 17:47 #35584
by Chando
Replied by Chando on topic stop and go while homing
I don't think the velocity is the problem. Same settings on the old pc worked fine. I have just changed the pc because it always gave latency error.
Regarding the freezing: I am using only emc . When freezes I can do nothing except restart.
13 Jun 2013 20:35 #35586
by cncbasher
which is probably why you had high numbers because of the latency ..
every pc is different ..
Replied by cncbasher on topic stop and go while homing
13 Jun 2013 21:57 #35587
by ArcEye
But they didn't did they, you kept getting realtime errors
If you choose to run with a completely untuned system, high base thread interval and insane acceleration, don't expect it to run smoothly.
Replied by ArcEye on topic stop and go while homing
13 Jun 2013 22:07 - 13 Jun 2013 22:09 #35588
by Chando
Yes this is true, but now I am with good setup
stepgen.dirhold and dirsetup are as you said under 30000. The velocity is low and again the machine is stopping times to times while searching the home position. I think I have troubles either with the pc or with linux installed, but how to find them. I see I can not change the time and date settings. Every time when reboot the time and date start form 00:00 and 2003 year december. I changed the motherboard battery, but the result is the same.
However thank all of you for suggestions. Please keep to write. I need to find and resolve the problem.
Last edit: 13 Jun 2013 22:09 by Chando.
Time to create page: 0.442 seconds
