Forum Header
Laptop MSI - COM1 port
20 Sep 2013 12:42 #39057
by probamo
Laptop MSI - COM1 port was created by probamo
The mentioned Laptop do not have LPT1, but checking Live CD on it, Latency test works quite well, w/o having any USB connection, max was 6500ns, with USB mouse goes up to 9500ns, which is quite good having in mind that testing is on laptop. I did not install LinuxCNC on HDD, just checked Latency with LiveCD.
Would the figures change when the system is installed on HDD? If not, this MSI laptop could be good candidate for driving machine.
Unfortunately, Laptop do not have LPT1, but COM1 connector. If adapter COM1/LPT1 is provided, would it be possible to configure stepconf and run the machine?
Is there any experience behind from the others?
Thanks,
Thanks,
20 Sep 2013 12:48 #39058
Replied by cmorley on topic Laptop MSI - COM1 port
if by COM1 you mean the serial port no - won't work.
can you add a PCMCIA parallel port ?
Chris M
Chris M
20 Sep 2013 12:55 #39059
by probamo
Replied by probamo on topic Laptop MSI - COM1 port
Or should this adapter help
www.virtikom.com/racunari/adapteri-3/int...serial-adapter-rs232
20 Sep 2013 13:02 #39060
Linuxcnc cannot send realtime motor commands over serial whether a standard or USB.
This includes USB to parallel port converters.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Emc2HardwareDesign
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
Chris M
Chris M
The following user(s) said Thank You: probamo
Time to create page: 0.130 seconds
