creating a pre-set
- somenewguy
- somenewguy
ish
and the micro stepping is always expected to be set by the user.
Oh wait - do you mean the sample configs or using stepconf to build a config?
Chris M
JT
- somenewguy
on a G540 microstepping is non-selectable, so there is no benifit to someone with a G540 not already being setup for the correct value when they choose a G540 based template. I may however be confused as to what drives the pre-sets in those boxes, so I will keep reading and digging as I can.
I have never personally used G540s, they are American, which means expensive over here. They are also quirky, eg. requiring higher current charge pump enable (EPP mode) etc.
One of their quirks appears to be micro-stepping. This is notionally fixed at 10X.
This is the figure that you need to input into calculations, ie 2000 steps per revolution.
According to info I have found, the driver will change the microstepping at higher speeds to full steps.
This actually sounds all good, until you think about what it does.
At high speeds it will move one 1.8 deg step for every 10 pulses it receives, so the software still has to produce the same number of pulses to travel the same distance,
it is just that the driver moves the motor a greater distance at a time.
The advantage will be that the motor is moving a real segment between rotor / magnet attraction and not an artificial interpolated one, which can only be more accurate and easier to achieve.
The 'disadvantage' is that this does nothing to assist the contraints of software pulse generation.
Add in 4:1 gearing and you might be limiting max velocities quite a bit on slow base thread machines, without the option to drop micro-stepping to say 4x, which is normally the highest I use.
To free yourself of these contraints, you will need to look at hardware generated pulses, if velocity is important or being limited by base thread speed and excessive micro-stepping
I believe the goal here was also to have the greater torque of a full step vs a micro step at higher speeds where it may be needed.
Rick G
I personally would not use a G540 because of how much trouble they can be to get running. I prefer the individual drives like the G203v and G251 which don't suffer from the main board problems in the G540.
JT
- somenewguy
maybe not worth the effort.
