Forum Header
Stepconf file for Max NC 10, 4 phase controller?
- rickm45@gmail.com
04 Aug 2014 03:55 #49467
by rickm45@gmail.com
Hi All,
I have a MAX NC 10 controller which appears to use 4 phases to drive the steppers. Does anyone have a sample of a stepconf file that I can work from to get started?
Best I can tell I have to map the PP pins like this:
Phase X Y Z
1 6 1 2
2 7 14 3
3 8 16 4
4 9 17 5
Thanks for any help,
Rick
Phase X Y Z
1 6 1 2
2 7 14 3
3 8 16 4
4 9 17 5
Rick
04 Aug 2014 19:03 #49489
by BigJohnT
Replied by BigJohnT on topic Stepconf file for Max NC 10, 4 phase controller?
The Stepconf Wizard only creates files with step type 0 with step and direction each on a pin.
There are 6 choices for 4 phase steppers.
linuxcnc.org/docs/html/hal/rtcomps.html#sec:Stepgen
You might have to start with a sample configuration and modify it to suit your machine.
JT
JT
- rickm45@gmail.com
05 Aug 2014 09:41 #49511
Replied by rickm45@gmail.com on topic Stepconf file for Max NC 10, 4 phase controller?
I have to agree on the sample configuration file. I think if someone has a configuration file for a 4-phase steppers, or any phased steppers, I could adapt it. In the meantime, I'll start working my way through the configuration process.
Thanks, Rick
Thanks, Rick
Time to create page: 0.101 seconds
