Forum Header
How to switch stepper rotation?
31 Aug 2014 09:14 #50542
by Dave H
How to switch stepper rotation? was created by Dave H
I bought a small 3 axis mill a while ago. Electronically it ran fine with LinuxCNC 2.5. The machine was in great need of a mechanical rebuild. I have now done that, but I want to mount the X and Y motors on the opposite ends of the screws than they were. So their rotation directions need to be reversed. Can someone tell me the changes I need to make to the .hal or .ini files to make this happen? Or is it more involved than that?
The only other changes I will need is to change the total travel of each axis, and hopefully I can figure that out.
31 Aug 2014 13:19 - 31 Aug 2014 13:36 #50545
by Rick G
Replied by Rick G on topic How to switch stepper rotation?
In your .ini file change the sign of SCALE for the axis you want to change direction.
www.linuxcnc.org/docs/devel/html/config/ini_config.html
So if
SCALE =1200
change to
SCALE = -1200
The travel is set with MIN_LIMIT and MAX_LIMIT
On a stepper system you can also invert the direction pin to reverse direction.
Rick G
So if
SCALE =1200
change to
SCALE = -1200
Rick G
Last edit: 31 Aug 2014 13:36 by Rick G.
The following user(s) said Thank You: Dave H
31 Aug 2014 15:49 #50546
by cncbasher
Replied by cncbasher on topic How to switch stepper rotation?
you can also move the wires of the stepper motor by reversing each pair of coils
so yes theirs the easy way , and a hard way
31 Aug 2014 17:51 #50549
by Rick G
I think you meant one pair (phase) of coils not both.
Rick G
Rick G
31 Aug 2014 19:48 #50551
by Dave H
Replied by Dave H on topic How to switch stepper rotation?
Thank you very much guys. Much appreciated!
Time to create page: 0.132 seconds
