Forum Header
Need help with spindle setup
31 Mar 2015 21:38 #57346
by muamerb
Need help with spindle setup was created by muamerb
I am using hitachi wj200 2.2 kw and chinesse spindle 1.5kw with gecko g540.
Tried to connect and run it with my laptop with analog control. Everthing works but one little problem. It is completely inverted. It starts wioth max RPM and when I issue m3 s1000 for.e. spindle runs 23000 RPM or, S10000 spindle goes 14000 or s500 spindle goes 23500 rpm or s23000 spindle goes 1000rpm . When I issue M5 spindle goes to max RPM or 400Hz. If anyone can spare me headache I would be very gratefull. My spindle is 400Hz 24000RPM max.
01 Apr 2015 13:21 #57362
by ArcEye
Replied by ArcEye on topic Need help with spindle setup
Hi
You need to attach your config files ( hal and ini).
Obviously something is backwards, but we don't even know what control method you are using
01 Apr 2015 21:56 #57386
by muamerb
Replied by muamerb on topic Need help with spindle setup
hey thank u for answer.
I tried to play with hal file but without man luck.
I measured pin 8 on gecko after i power up and it shows 9.8V. With m3 and slower speeds it voltage goes down and with m5 signal is max again . Guess that is correct. Tried also to find some settings on hitachi wj200 to invert the signal that it gives less frequency with bigger voltage but couldn't find any option like that .
Ill upload my hal and ini later.
01 Apr 2015 21:58 #57387
by muamerb
I wrote with slower speeds voltage goes down ... it is opposite
sorry for my english
it sucks
it sucks
01 Apr 2015 22:34 #57390
by muamerb
Here is my hal and ini
01 Apr 2015 22:35 #57391
by muamerb
01 Apr 2015 22:47 #57392
Replied by PCW on topic Need help with spindle setup
try changing:
setp parport.0.pin-14-out-invert 1
to:
setp parport.0.pin-14-out-invert 0
to:
The following user(s) said Thank You: muamerb
01 Apr 2015 23:25 #57396
by muamerb
Thank u i will try that one soon as finish with book shell .... wife is priority
02 Apr 2015 01:45 #57403
by muamerb
It camed up to be simple as that .... thank u very much
Time to create page: 0.179 seconds
