Forum Header
Trouble when testing Estop during axis test
27 Apr 2015 09:52 - 27 Apr 2015 09:53 #58147
by jjacob
Trouble when testing Estop during axis test was created by jjacob
This is my first time dealing with linux cnc. When working with stepConf, I have the following setup:
C10 breakout board with Emergency stop switch connected to pin 10 and ground
Parallel port 0x378 ->out (verified in bios)
Parallel port bios setting: EPP/ECP
input pin 10 ->Estop in
Output pins all work fine at controlling all motors. When testing an axis in stepConf, machine does not respond to the emergency stop input.
I have used the parallel port tester here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester to verify that a signal is being received
on input port 10 when the emergency stop switch is engaged.
Does anyone have any idea why the machine is not stopping?
Thanks,
-Jeremy
Thanks,
-Jeremy
Last edit: 27 Apr 2015 09:53 by jjacob. Reason: Incorrect title
27 Apr 2015 14:50 #58148
by ArcEye
There is no EStop test in stepconf, the test is just for the motors.
Does it work when you run your machine on the generated config?
If not post your hal and ini files
Replied by ArcEye on topic Trouble when testing Estop during axis test
27 Apr 2015 22:17 #58163
by jjacob
Replied by jjacob on topic Trouble when testing Estop during axis test
I was wondering if this could be the case. I'll test this on the generated config and let you know. Thanks!
28 Apr 2015 07:43 #58178
by jjacob
You are absolutely right. It works without a hitch in the main GUI. Thank!
Time to create page: 0.264 seconds
