Forum Header
synchronisation problem when using M3 command
07 May 2015 16:38 #58474
Replied by andypugh on topic synchronisation problem when using M3 command
If you are using Axis does the graphical preview appear correct?
Is it always the Y axis that has the problem?
If this is a 4-axis board you could switch the Y axis to the 4th channel and see if that helps (you just need to alter the parallel port pin numbers in the HAL file)
07 May 2015 16:51 #58475
by devlies
Replied by devlies on topic synchronisation problem when using M3 command
@andypugh I will try your suggestion. But still when M3 S1 is used the Y axis seems correct and when M3 S1000 is used the Y seems to fail ? It feels like the linux or the computer has calculation problems with high M3 S values. But still trying and thanks a lot.....
07 May 2015 17:06 #58477
This is easy to test, change the pwmgen.0.scale value so that S1 = full speed. Then I suspect that you will see exactly the same effect at S1 as you see now at S1000.
I am convinced that if there was an interaction between spindle speed and the Y-axis in the software that it would have been noticed by now...
07 May 2015 18:51 #58478
by devlies
@andy thanks a lot !!!!!
we changed the Y axis to the A axis connections on the breakoutboard and it seems much better. Thanks again for your insight.
Pieter Devlies
vives technical college
Ostend
Belgium
Pieter Devlies
Ostend
Belgium
07 May 2015 21:31 #58484
by devlies
Pieter Devlies
Ostend
Belgium
Pieter Devlies
Ostend
Belgium
