Forum Header
Conf Ok for max speed. For other doesn't works ok
20 Jun 2015 17:57 #60011
by Rick G
O.K.
Go into the ini file and reduce SCALE by 1/2 for the axis you are working on and check the results.
Rick G
Replied by Rick G on topic Conf Ok for max speed. For other doesn't works ok
I reduced in ini file the velocity and acceleration of the axes in a half. Now, for any value of F the distance traveled is doubled in the three axes. I have a multiplication factor of two.
O.K.
Rick G
01 Jul 2015 21:31 #60309
by Marfil
Replied by Marfil on topic Conf Ok for max speed. For other doesn't works ok
Hi all.
Finally my problem was fixed.
I switched the Driver Microstepping from 2 to 1 and that´s all.
Currently in x axis in 1meter of travel lenght, the error is 1 mm (1/1000). The other two axes are working pretty good too.
Mission accomplished. Thanks for your support.
Marfil
Marfil
Time to create page: 0.117 seconds
