Forum Header
In custom_postgui.hal ?
08 Oct 2015 21:51 #63575
by gaston48
In custom_postgui.hal ? was created by gaston48
Hello,
What is this instruction in custom_postgui.hal Stepconf with (2.7.0)
"sets spindle-at-speed true" ?
It can be found here:
git.linuxcnc / .... /stepconf/build_HAL.py
Thank you
Thank you
08 Oct 2015 22:00 #63576
by cncbasher
Replied by cncbasher on topic In custom_postgui.hal ?
this sets the spindle speed indicator panel , as you dont have any encoder to feedback the rpm ,
this overides the display .
08 Oct 2015 22:23 - 08 Oct 2015 22:36 #63578
by gaston48
Replied by gaston48 on topic In custom_postgui.hal ?
Thank you cncbasher !
Why "sets" and not "setp" ? it is not a hal instructions
Some documentation somewhere ?
Last edit: 08 Oct 2015 22:36 by gaston48.
08 Oct 2015 23:21 #63580
by dgarrett
or for man page:
Replied by dgarrett on topic In custom_postgui.hal ?
$ halcmd help
Use 'help <command>' for more details about each command
Available commands:
loadrt Load realtime module(s)
loadusr Start user space program
waitusr Waits for userspace component to exit
unload Unload realtime module or terminate userspace component
lock, unlock Lock/unlock HAL behaviour
linkps Link pin to signal
linksp Link signal to pin
net Link a number of pins to a signal
unlinkp Unlink pin
newsig, delsig Create/delete a signal
getp, gets Get the value of a pin, parameter or signal
ptype, stype Get the type of a pin, parameter or signal
setp, sets Set the value of a pin, parameter or signal
addf, delf Add/remove function to/from a thread
show Display info about HAL objects
list Display names of HAL objects
source Execute commands from another .hal file
status Display status information
save Print config as commands
start, stop Start/stop realtime threads
alias, unalias Add or remove pin or parameter name aliases
echo, unecho Echo commands from stdin to stderr
quit, exit Exit from halcmd
or for man page:
$ man halcmd
08 Oct 2015 23:28 - 09 Oct 2015 02:58 #63581
by gaston48
Oh thank you very much, I did not well look for
Last edit: 09 Oct 2015 02:58 by gaston48.
09 Oct 2015 02:43 #63586
by BigJohnT
Replied by BigJohnT on topic In custom_postgui.hal ?
Time to create page: 0.081 seconds
