Forum Header
How to see parameters previously used in a config.
02 Dec 2015 17:00 #66215
by hickbooz
How to see parameters previously used in a config. was created by hickbooz
Hi all,
I want to know if it is possible to see the values used in a configuration of the linuxcnc. I want to know the parameters pulses per revolution and max velocity that I used in a configuration, to use these parameters on my drivers, but i coulndt do it.
Any help on this guys?
Thanks!
Thanks!
02 Dec 2015 17:37 #66217
by ArcEye
Replied by ArcEye on topic How to see parameters previously used in a config.
Hi
Look at your .ini file in /home/your-user-name/linuxcnc/configs/config-name/config-name.ini
For each axis towards the bottom of the file, you will have
MAX_VELOCITY =
SCALE =
MAX_VELOCITY is units / sec
SCALE is pulses / unit
If you want to see the figures as you entered them into stepconf, then choose 'Open existing configuration' and choose the config-name.
Just don't finish or save, just quit from it when done.
MAX_VELOCITY =
SCALE =
The following user(s) said Thank You: hickbooz
05 Dec 2015 11:46 #66448
by hickbooz
Replied by hickbooz on topic How to see parameters previously used in a config.
Thank you man! This help me to see the velicty and pulse in each axis, but when I try to 'open existing configuration', I can not see any file to open on the folder that my configurations are. So I cannot see the configuration per pin and see exactly what I put in the last configuration...
Any idea of why I cannot see the configuration files?
Thanks again!
Thanks again!
05 Dec 2015 12:20 #66450
by ArcEye
Open the file manager and look through your home folder.
If you used stepconf for the config, the .stepconf file will be somewhere in there, probably in the configs folder or in with the actual config itself
If necessary copy it to wherever stepconf is looking when you try to open it
05 Dec 2015 12:56 #66453
by hickbooz
I was looking at the wrong place. Sorry for the incovinience, thanks for the help!
Time to create page: 0.168 seconds
