Forum Header
sim_hardware inverted input pins do not exist?
23 Jan 2016 20:31 #68996
by summetj
sim_hardware inverted input pins do not exist? was created by summetj
I used the StepConf wizard to set things up, and it all worked right up until I tried to invert an input for a home switch.
As soon as I inverted an input in the StepConf wizard, I get the following error when I try and start LinuxCNC 2.7.3:
sim_hardware.hal:29: Pin 'parport.0.pin-10-in-not-fake' does not exist
I'm using the 2.7 ISO image I downloaded a few days ago, I don't know the exact version of the StepConf wizard, but it is whatever was shipped with that ISO image.
Anybody seen this before and know the magic solution?
Thanks,
Jay
Thanks,
Jay
24 Jan 2016 04:43 #69023
Replied by cmorley on topic sim_hardware inverted input pins do not exist?
there is a fix for this when 2.7.4 is released.
If running real hardware this should not be a problem.
Chris M
Chris M
Time to create page: 0.313 seconds
