Forum Header
The Express pci parport card address .What?
20 Aug 2016 22:25 #79182
by 819132306
Replied by 819132306 on topic The Express pci parport card address .What?
I did not install the parallel port driver is not required to drive with the linuxcnc port?
- Thank you received: 5927
20 Aug 2016 22:30 #79183
Replied by tommylight on topic The Express pci parport card address .What?
You can update the BIOS but i do not think it will help, and latency on my X220 ( i had several of them ) was over 2000000 (2 milion).
If you can get a latency of 15000 you are all good, but not with a paraport, use a MESA ethernet card like 7i92E, that would be perfect.
20 Aug 2016 22:32 #79184
No, normally you do not need to install drivers, Linux has drivers for most of them ( all that i had come across worked )I did not install the parallel port driver is not required to drive with the linuxcnc port?
The following user(s) said Thank You: 819132306
20 Aug 2016 22:40 #79185
by 819132306
thankyou
I know, but I am a Chinese, in the country can not buy mesacard. because Internet restrictions, mesacard does not seem to sell to the Chinese people, and sincerely hope that you can buy a mesacard in www.taobao.com, so only use parallel play.
I did not install to parallel port Expresscard34mm driver, I will try again
20 Aug 2016 23:21 #79188
by 819132306
this is a PNP
May be a bit different, I am looking at some of the previous posts
21 Aug 2016 08:48 #79193
by 819132306
qqqqqq@yyy:~$ lsmod
Module Size Used by
usblp 17091 0
joydev 16848 0
usbhid 39608 0
hid 72252 1 usbhid
cryptd 14126 0
aes_i586 16648 1
aes_generic 37067 1 aes_i586
bnep 17186 2
rfcomm 36117 0
bluetooth 166348 10 bnep,rfcomm
uinput 17057 1
nfsd 202675 2
nfs 277039 0
nfs_acl 12464 2 nfs,nfsd
auth_rpcgss 32226 2 nfs,nfsd
fscache 35490 1 nfs
lockd 56898 2 nfs,nfsd
sunrpc 151263 6 nfs,nfsd,auth_rpcgss,lockd,nfs_acl
loop 21832 0
parport_pc 21896 0
ppdev 12591 0
lp 12767 0
parport 35208 3 lp,ppdev,parport_pc
snd_hda_codec_conexant 44406 1
arc4 12419 2
evdev 17099 28
coretemp 12771 0
psmouse 67176 0
serio_raw 12734 0
snd_pcsp 13463 1
iwlwifi 182871 0
mac80211 224518 1 iwlwifi
cfg80211 150489 2 iwlwifi,mac80211
iTCO_wdt 16918 0
iTCO_vendor_support 12586 1 iTCO_wdt
snd_hda_intel 25789 1
i2c_i801 16788 0
snd_hda_codec 79439 2 snd_hda_codec_conexant,snd_hda_intel
snd_hwdep 12911 1 snd_hda_codec
snd_pcm 69181 3 snd_hda_codec,snd_hda_intel,snd_pcsp
snd_page_alloc 12842 2 snd_pcm,snd_hda_intel
snd_timer 22188 1 snd_pcm
shpchp 30674 0
thinkpad_acpi 59724 1
nvram 12854 1 thinkpad_acpi
wmi 17148 0
i915 360470 2
snd 46731 14 snd_hwdep,snd_timer,snd_hda_codec_conexant,snd_pcm,snd_hda_codec,snd_hda_intel,thinkpad_acpi,snd_pcsp
battery 12987 0
soundcore 12891 1 snd
rfkill 18403 5 cfg80211,thinkpad_acpi,bluetooth
ac 12553 0
power_supply 13320 2 ac,battery
drm_kms_helper 26601 1 i915
drm 169993 3 i915,drm_kms_helper
tpm_tis 17138 0
tpm 17590 1 tpm_tis
tpm_bios 12778 1 tpm
i2c_algo_bit 12648 1 i915
i2c_core 23097 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video 17461 1 i915
thermal_sys 17699 1 video
button 12818 1 i915
ext4 270189 1
crc16 12328 2 ext4,bluetooth
jbd2 54294 1 ext4
mbcache 12899 1 ext4
sg 25482 0
sr_mod 21529 0
sd_mod 43403 3
cdrom 38893 1 sr_mod
crc_t10dif 12333 1 sd_mod
ahci 24918 2
microcode 17386 0
uhci_hcd 26254 0
libahci 22312 1 ahci
ehci_hcd 43561 0
usbcore 124257 5 usblp,uhci_hcd,ehci_hcd,usbhid
e1000e 133515 0
usb_common 12339 1 usbcore
ata_generic 12440 0
libata 152992 3 ahci,libahci,ata_generic
scsi_mod 125436 4 sg,libata,sd_mod,sr_mod
qqqqqq@yyy:~$
Module Size Used by
usblp 17091 0
joydev 16848 0
usbhid 39608 0
hid 72252 1 usbhid
cryptd 14126 0
aes_i586 16648 1
bnep 17186 2
rfcomm 36117 0
uinput 17057 1
nfsd 202675 2
nfs 277039 0
fscache 35490 1 nfs
loop 21832 0
parport_pc 21896 0
ppdev 12591 0
lp 12767 0
arc4 12419 2
evdev 17099 28
coretemp 12771 0
psmouse 67176 0
serio_raw 12734 0
snd_pcsp 13463 1
iwlwifi 182871 0
iTCO_wdt 16918 0
i2c_i801 16788 0
shpchp 30674 0
wmi 17148 0
i915 360470 2
battery 12987 0
ac 12553 0
tpm_tis 17138 0
tpm 17590 1 tpm_tis
video 17461 1 i915
button 12818 1 i915
ext4 270189 1
jbd2 54294 1 ext4
sg 25482 0
sr_mod 21529 0
sd_mod 43403 3
ahci 24918 2
microcode 17386 0
uhci_hcd 26254 0
ehci_hcd 43561 0
e1000e 133515 0
ata_generic 12440 0
qqqqqq@yyy:~$
21 Aug 2016 13:30 #79196
loop 21832 0
parport_pc 21896 0 <=======there should be 1 instead of 0
ppdev 12591 0
lp 12767 0
loop 21832 0
ppdev 12591 0
lp 12767 0
21 Aug 2016 13:35 #79197
by 819132306
I opened the to parllel port Expresscard today, the results found that the USB bus, I have to change a Expresscard.
thank you for your reply,
21 Aug 2016 13:37 #79198
by 819132306
Does this mean that there is no parallel and inserted?
loop 21832 0
ppdev 12591 0
lp 12767 0
21 Aug 2016 13:54 #79200
In a word, yes.
Even if it is inserted, Linux can not see it so it can not use it.
Linux will not work with USB>Paraport converters.
There is one mentioned here that works with Linux. www.astrosnap.com/telescope_control_adapters.html
Time to create page: 0.281 seconds
